AJ's Sky UK Channel List **Discussion** Thread
Page 1 of 256 1234561151101 ... LastLast
Results 1 to 15 of 3831
    Nov 2011
    Default AJ's Sky UK Channel List **Discussion** Thread
    When I unzip this file it has no extension and its not recognised by the OpenBox
    Stone
  2. The Following 3 Users Say Thank You to stonestaff For This Useful Post:
    madmanuk (4th July, 2014), stefmc26 (2nd June, 2017)
  3. #2
    with no $ on channel dont think it lets you ts or record a no it dont on s9 tried it months ago
    Mar 2012
    when i update why am i only seeing 8 fav not 25?
    maybe u need to do a factory default first?, but remember it might wipe important things,make sure u save them first etc
  6. The Following User Says Thank You to Wingnut For This Useful Post:
    a7v8x (29th June, 2013)
    Junior Member tjnwil4's Avatar
    Nov 2008
    thanks great channel list just need a better epg and were cooking with gas
  8. #6
    DK Veteran DeejayAJ's Avatar
    Feb 2012
    Quote Originally Posted by smithie46 View Post
    Yeah you're right, just tested it on my S12.. odd, thanks.
    Updated OP.
  9. The Following User Says Thank You to DeejayAJ For This Useful Post:
    Awalla (5th February, 2014)
  10. #7
    DW190
    Guest
    Quote Originally Posted by f1nuts View Post
    Probably because the software on you box is only capable of eight. Updating the software may cure it.
  11. #8
    Feb 2011
    put these onto my Openbox S10 and now the box is dead? Nothing displays can anyone help?
    Cheers
  12. The Following User Says Thank You to brithepi2k For This Useful Post:
    mamouth123 (10th July, 2013)
  13. #9
    Feb 2012
    Quote Originally Posted by brithepi2k View Post
    Cheers
    All 4 of these files has been tested on my S12 & work fine. Did you edit the files? Could you have rebooted before the flash had ended? Which list was it?
  14. The Following User Says Thank You to DeejayAJ For This Useful Post:
  15. #10
    A ch list cannot kill a stb, simple as that.
  16. The Following User Says Thank You to Manic01 For This Useful Post:
    chrisxxx (18th July, 2013)
  17. #11
    Feb 2011
    Quote Originally Posted by DeejayAJ View Post
    Its ok for some reason a faulty usb was able to transfer the files to my box but when i upgraded by usb and that had complete i turned my box off and on and it was dead waited a good 5 minutes to see if it turned on but nothing was displaying then had to put the firmware back on the box...
  18. #12
    Mar 2012
    Cheers
    Restart your s10 and the channels will reappear. The same happened to me so I tried a restart and it works a charm.
  19. #13
    Mar 2012
    Thanks for the List? Any idea how Can I edit this and revise according to my requirement.
  20. The Following 5 Users Say Thank You to irfansaeed For This Useful Post:
    amolak1999 (30th June, 2013), colib23 (26th March, 2013), karis (4th August, 2013), phillip123 (7th July, 2013), tahaathed (1st August, 2013)
  21. #14
    Feb 2012
    Quote Originally Posted by irfansaeed View Post
    S9-Editor_HD.zip
  22. The Following User Says Thank You to DeejayAJ For This Useful Post:
    paul93 (27th November, 2015)
  23. #15
    Feb 2011
    Sound is out of sync for me when someone talks...
  24. The Following User Says Thank You to brithepi2k For This Useful Post:
    Gray1 (8th June, 2014)
