Try the oldest version of Dreamup you can find.
Another option is using flashwizard.
Load a Neutrino image to bring the box back to life.
You can then upload any othe image that you like.
If all fails then you need to Jtag the box.
help needed ..with dm7000s ...when trying to flash using null modem i get ( ERROR, flash-erase failed, box will be unusable now!!) ......so i tried to use (erase.img) file to clean up every thing and start again didnt work i get error ( Found no valid jffs2 in image flash-erase not supported!)... tried with different versions of dreamup still box lcd stuk on orange display with dm logo ,out put to tv black screen .tried to up load the original image for box still no joy ...note box never been flashed before had the original enigma on it before this and was 100% working ). .....any help is appreciated .thanks
