    DK Veteran Lyrrad's Avatar
    Apr 2008
    Default Prolific USB to Serial driver
    This is pretty obscure but it might help others.
    I have a Garmin Etrex H handheld GPS device that I use for geocaching. It's quite old but is a good model. It connects via serial cable but many people have USB to serial cable. Most people would have this on XP and if you do a search online you will find many many posts stating that they can't get GPS unit (or other devices that use Prolific ) working on win 7. There does seem to be a link on website of Prolific for win 7 drivers but many people state they don't work and nearly all say they don't work for 64bit. Prolific state it's because of cheap Chinese tat connector cables but I don't think so. My cable has worked in the past but not now.
    I have trawled internet for hours over the past 2 days and eventually came up with a solution.
    Uninstall Prolific USB to serial using windows uninstall, then just unzip file here. By the time I found this I was ready to give up and buy a new GPs unit.
    It works for me on WIn 7 64 bit Ultimate.
    Aug 2012
    thanks for this
    Aug 2012
    Thanks for this!
    Oct 2012
    Will try this. Hope it helps
    Dec 2012
    Smile
    will try this out, hope this helps!
    thanks!
    Dec 2012
    Thanks for this!
