up for help?
thank you
hi,
Someone can help?
W211 E280CDI MY2006 (end 2006) with dash A211.540.08.48
VDO PN 110.080.330/008
problem after a dump crash.
I tryed several dumps and now, everything seems to be OK exept tachometer pointer that moves very very slowly.
I tested the pointer motors with Xentry > there are OK and move fast! (strange?)
So if someone could provide a virgin .bin dump that could match with this ref, it will be welcomed !
regards,
GeD
up for help?
thank you
try this dump
thanks a lot, I will try it asap and give you feedback.
Dear Ion Cristi,
Dump is working fine !!!! tacho and speedo are OK !
just 1 thing :
when engine start, exterior lamps goes ON, even if light contactor is OFF.
any idea? is this dump CAN blocked? if yes, can you modify it to enable CAN?
regards,
GeD
I did the learning process, but xentry tells that there is a CAN communication error...
and for complete SCN coding, do I need a special code from factory?
thank you.
up please (sorry)
anyone can check if the joined dump is CAN modified? I want KI to dialog with EZS.
thank you for your help.
GeD
We urgently need this dump but it is damaged after downloading.
I have the same problem as gedeon25.
Please reply.
My cluster is A 211 540 09 48
Ori dump is damaged and other dumps are not working with this tachometer.
