Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
  1. #16
    May 2010
    here is Dump need immo OFF
  2. #17
    Oct 2010
    Greece
    from immobox or from ecu ??? flash or eeprom 24c02 ? ??
  3. #18
    Oct 2010
    Greece
    Post solved with pair set and done...
  4. #19
    May 2010
    I Tested Vasko File but Not Done
  5. #20
    Aug 2016
    Default kia sportage immo off work?
    hi mate i has same ecu need off .. ur car immo off work?/.. can share the flash 29f010b .. ols
  6. #21
    Mar 2017
    Malaysia
    Default Need immo off
    hi mate i has same ecu need immo off
    redpunk
  7. #22
    Jul 2018
    Hi friends how the problem solved pleas can you give me the files on my emila xxxxxxxxxxxxx
  8. #23
    Newbie AdeptusPredator's Avatar
    Jun 2020
    Russia, Samara
    Hi! I have the same car, only 1999.
    The ECU is exactly the same: K08H FED EU M261206566 BOSCH.
    And the problem is almost the same. After a smooth discharge of the battery,
    Immo and ECU synchronization failed. In order to eliminate this problem in the future, it was decided to remove Immo from the system.
    Who can help with the modified firmware for K08H Immo off.
    Quote Originally Posted by mellon View Post
    I need good solution for immo off in car Kia Sportage 1998year 2.0 gasoline,
    K08H FED EU
    M261206566
    BOSCH
    B58253(24C02) and B58399(29F010)
    Please help.
  9. #24
    Jul 2017
    HI. Could you possibly assist with advising on the power amp and wire, from old to new point for the Kia Sportage immo off 2.0 K08H M261206566. Your assistance would be appreciated
  10. #25
    Jul 2017
    IMMO off :You have to desolder eprom, program 29f010 immo off file, change position power amp driver and solder wire form old postion to new position IC.
    Vasko send you file to automatic immo learn by ecu. So you must program eprom ecu vasko files and put 2 times ignition on, do not cranking!
    If Vasko solution not work please send information than I send you my immo off solution.
    HI can you please assist with the above location of the link from old power amp to new position for immo off to work correctly.
    Vehicle is starting but no rpm and sound like it's running on two cylinders(misfire)
  11. #26
    Jul 2019
    hungary
    Üdvözlet Mellon.
    tudna nekem segíteni a Vasko fájlok telepítésében?
    A téma egy Kia Sportage 2.0.
    Az indításgátló hibás, és nem indul el.
  12. #27
    Jul 2017
    Quote Originally Posted by wins96 View Post
    Üdvözlet Mellon.
    Could you please translate,don't understand.
    Thank you
  13. #28
    Default K08H kia sportage immo off
    Quote Originally Posted by vasko View Post
    this is for you.../
    Regards Vasko, Bulgaria
    Hi, dear
    I m looking for immo off file for
    KIA sport age M261 206 566
    K08 FED EU
    Could you help me pls.
