Page 1 of 11 123456 ... LastLast
Results 1 to 15 of 160
    Mar 2012
    Central EU
    Default AUTOCOM TRUCKS VANS and CARS - all in one
    To use AUTOCOME to diagnose cars, vans and trucks you should only change a serial number of interface.
    If I helped you - use 'Thanks' button.
  2. The Following 9 Users Say Thank You to chris5390 For This Useful Post:
    BUSCADOS (20th October, 2020), cetateharman (24th January, 2021), Cmext (5th November, 2021), corky2019 (14th November, 2019), GIUSEGIOVANNA (13th December, 2018), mps125 (18th February, 2021), onur61 (26th October, 2013), snowre (7th May, 2020), turgutsan (15th February, 2020)
  3. #2
    DK Veteran elchip's Avatar
    EU
    Post
    Quote Originally Posted by chris5390 View Post
    So you offer free to all china hunter's on forums to tommorow sale 2 in 1 ahhhh my man ....
    [I]Automotive Electronics Solutions
    Mercedes-Benz Reverse Development Engineer ...
    Mercedes CFF 2010-2017 CFF all models all modules
    Vediamo help flashing over teamviewer ...
    JLR SDD online + offline ...last official ...
    I have tryed this solution and all I got now is "USB DEVICE NOT RECOGNISED" when plug CDP to USB port!
    Tested on SW, but "NO VCI" error is diplayed!
    Anyone can help to solve this, becouse interface is now dead???
    Mar 2012
    Central EU
    Quote Originally Posted by elchip View Post
    My solution V2 automatically changes the SN after starting T or C.
    Password by PM
  6. The Following 3 Users Say Thank You to chris5390 For This Useful Post:
    cetateharman (24th January, 2021), mps125 (18th February, 2021), onur61 (26th October, 2013)
    EU
    Post
    BRAVO BRAVO ..... u are GENIUS ...
    And after that all work OK all car and all heavy duty hehehe
    OPEL , BMW , VOLVO , FORD
    You dont have message " VCI NOT FIND "
    I suspect ...
    Regard's
  8. #6
    Mar 2012
    Central EU
    Quote Originally Posted by alfy View Post
    damaged after the change of SN ... hmmm
    is impossible ...
    after changing the firmware - yes
    after changing the serial number - no
    sn is a open text
    I understand
    .... no comment
  9. #7
    Mar 2012
    Central EU
    This is pathetic
    I thought that this forum is only to help
    I was wrong
    This is a business forum
  10. #8
    is impossible ...
    sn is a open text
    I understand
    .... no comment
    When "readserial" command was sent nothing showed!
    Only I heard was the sound that windows disconected device (like pulling out the USB).
    Now tryed on 3 PC, win7 and XP but always "DEVICE NON RECOGNISED" i think something gone in FTDI now...
    All the settings on speed and port was OK, double checked!
    Maybe I wasn't lucky... but now need some solution to bring CDP alive again!
    Till now I programmed serial by programming attiny... this is big shotcut if works ok!
  11. #9
    morfej's Avatar
    Why I read somewhere in the other thread that voltage that capatitors can handle in Cars CDP clones are lower than 24V ?
    ... so at least that should be checked before try tu user car CDP on trucks.
  12. #10
    Mar 2012
    Central EU
    I tested two clones, CARS and TRUCKS
    the difference is only in the color of the OBDII
  13. #11
    There are some more different interfaces on the market. They are with yellow, blue or red obd connector, but more important is the pcb inside.
    There are different relays, different capacitors (voltage), pcb with/without oki chip, wrong k-line resistors (390k should be) and maybe more...
    Sometimes they have problems with ford or bmw, truck connectors are wrong wired, volvo trucks don't work, firmware update 2011-3 doesn't work...
    It's a little bit lottery what you get.
  14. #12
    hello
    where i can find this prog cdp serial changer
    best regards
  15. #13
    furburger
    Guest
    Can you have cars and trucks installed on same HD ? Then just run one the utilities at the beginning if this thread to change serial then that allows you to run either program?
  16. #14
    Elchip you are like china seller , and stop crying please
    You should open your store in china. In pm you only offer help for $$$ so f... U
  17. #15
    smokey08's Avatar
    Essex, UK
    Here is Autocom Trucks 2011.1. Password is "digital-kaos" without the quotes.
    Part1
    Part2
    Part3
    Part4
    Part5
    Part6
    Part7
