Hi Happy_Highlander
Thanks for the response so if I cut down on the FAV will it work if so I think I read somewhere the max is 16
any info would be great and again thanks.
Hi Happy_Highlander
It should work if there are only 16, I'll try it tomorrow but I can tell you now I won't use it, I've looked at it with ct editor and it looks like a blind scan with the amount of duplicate channels on it.Hi Happy_Highlander<br />
<br />
Thanks for the response so if I cut down on the FAV will it work if so I think I read somewhere the max is 16 <br />
No Prob
Thanks for testing let me know if it works if you get a chance
"looks like a blind scan with the amount of duplicate channels on it." can you explain this as I thought I had all the FAV sorted into groups instead of Blindscan what should I be doing.
Thanks again
You have loads of the same channel.....download my list from this thread and use clarke tech editor studio to open it on pc and you will see the difference.
Edit....I'll put all other responses on your other thread and try to keep this one clear for questions about the list the thread is intended for.
Tp Changes to ITV1 HD Central West, STV HD and Dave without adult Digital Kaos - Downloads - 28.2 Channel List for tm 5402/bm7000 29-06-12 and TVX Amateur has stopped broadcasting on adult Digital Kaos - Downloads - 28.2 Channel List for TM5402/BM7000 29-06-12 Adult
Few tp changes and some more olympic channels added without adult Digital Kaos - Downloads - 28.2 Channel List for tm 5402/bm7000 09-07-12 and with Digital Kaos - Downloads - 28.2 Channel List for TM5402/BM7000 09-07-12 Adult
Just tried this on my BM7000s. Epic is the word I'd use for it. Subscribed mate. Thanks!
well said, OP has and is spending ages on the channel list for DK members.. more chance someone will test it if you make your own thread.
Not to forget, we do appreciate your effort and willingness to share your work but it is very irritating when someone changes the direction or discussion in your thread.
Read the Rules here; they apply to EveryOne.
__________________________________________________
DM800s HDOpenbox S10
TM500
DM500s
90cm FortecStar dish
Technomate 2300 motor powered by UsalS
MTV HD UK, MTV one UK and MTV one +1 added and the other 8 olympic hd channels and tp change to gold without adult Digital Kaos - Downloads - 28.2 Channel List for tm 5402/bm7000 11-07-12 and with Digital Kaos - Downloads - 28.2 Channel List for TM5402/BM7000 11-07-12 Adult
Hi mate
Got a small issue. The Sky 3D channel from your package doesn't seem to want to work. Now when I do an auto scan, I get multiple SKy 3D's and one of them works for me.
Now I ask, do you know if there is a way to add a single channel to your great list or can you maybe add all the Sky 3Ds to your list and allow me to delete the one that doesn't work?
IGNORE: Figured it out. Thanks
When i have transferred this to my blade media it does not have seemed to put them in order as channel 2 is BBC 1 HD channel 401 is sky box office HD
Any help ?
Yes they are in order they are in the order I put then in. This list is not supposed to match the sky numbers. You are also on all sats, if you go to hd favourites bbc 1 hd is 1. If you look the channel to populate the epg is first on the list so that it will always start on that channel after list installation you then only have to hit the epg button and leave it a minute to populate the 7 day epg. This way you don't have to go looking for epg channel
Use this one then http://www.digital-kaos.co.uk/forums....php?p=1492519 not sure how up to date it is but it should be ok
