Page 1 of 35 12345611 ... LastLast
Results 1 to 15 of 516
    happy_highlander's Avatar
    Aug 2010
    Default 28.2? East Channel List for TM5402, BM7000s, DrHD F15/D15
    I've put this list together and thought I would just stick it on here for anybody else that wants it..All the other lists I've found had way too much unnecessary channels. As this is the list I'll be using it should be kept up to date with any transponder changes. There are no **** channels cause they are british sh1te and I don't subscribe to them AND I've seen the program with the woman who does the voice over moans and groans, so here you go I hope it saves some of you some time Digital Kaos - Downloads - 28.2e Channel List for tm 5402/bm7000 Forgot to mention 16 Favorites Catagories have also been sorted.
    The most up to date channel lists can be found nearer the end of the thread.
  2. The Following 6 Users Say Thank You to happy_highlander For This Useful Post:
    akbarirfan (24th June, 2015), BagusCahyoJayaP (22nd December, 2021), dougie1970 (26th January, 2014), jon50 (31st March, 2014), WOODWARD395 (9th October, 2014)
  3. #2
    Aug 2010
    Ok here's the updated list Digital Kaos - Downloads - 28.2e Channel List for tm 5402/bm7000 14-05-12 Movies for men 2/ +1 have stopped broadcasting and sony movies/ +1 have started broadcasting couple of more transponder changes and a few other errors I hadn't noticed.
    Nov 2008
    Hello will this work on the Blade 7000 combo
    Aug 2010
    Quote Originally Posted by nsw9154 View Post
    Should do as long as it uses a .cndf channel list file
  6. The Following User Says Thank You to happy_highlander For This Useful Post:
    Nov 2008
    How do i load them in to the blade do i just fit it on a USB stick and upload it and is their any thing else i have to do,as i try not to mess about to much as i lost my clines once
  8. #6
    Aug 2010
    I would think so mate. I use a tm not a blade but they are pretty similar. So it should be extract list to usb, plug usb in then select data transfer and click ok on the channel list. The wording may be slightly different on your menu but I'm sure you get the jist of it.
  9. #7
    Aug 2010
    As requested by a few lazy mates I've added the adult channels to the list Digital Kaos - Downloads - 28.2e Channel List for tm 5402/bm7000 14-05-12 Wit
  10. The Following 2 Users Say Thank You to happy_highlander For This Useful Post:
    BagusCahyoJayaP (22nd December, 2021), mk7975 (2nd February, 2015)
  11. #8
    Nov 2008
    Quote Originally Posted by happy_highlander View Post
    They are the 1st Channels that i BIN i would rather watch MOTORBIKES
  12. The Following User Says Thank You to nsw9154 For This Useful Post:
  13. #9
  14. #10
    Thanks m8 its hard to get any channel lists for the 7000
  15. #11
    Aug 2010
    Quote Originally Posted by Grenadekid View Post
    Not any more it's not, this is the list I use so is always up to date
  16. #12
    Dec 2011
    i cant get sports hd channels even after try to scan a few times....by adding a fav list would that work?
    thanks for any advice
    tm5402
  17. #13
    Aug 2010
    Here is the updated channel list with these changes, Red Hot Fetish and Reality hub have gone and cream and filth have been added fta. Digital Kaos - Downloads - 28.2e Channel List for TM5402/BM7000 Adult changes to adult channels only
  18. The Following 2 Users Say Thank You to happy_highlander For This Useful Post:
  19. #14
    Aug 2010
    Quote Originally Posted by neallnufc View Post
    tm5402
    Why are you re-scanning after adding a channel list ??????? The idea of the list is that I have already done the hard work for you everything is set up favourites the lot, just install the list from usb and pick a channel to watch...
  20. #15
    Aug 2010
    I'm not ignoring the olympic channels but as there is no rush for them I'll upload the list once all 24 have settled tp's and the likes
  21. The Following 3 Users Say Thank You to happy_highlander For This Useful Post:
    a123456a (28th September, 2014), BagusCahyoJayaP (22nd December, 2021), woodle77 (7th October, 2016)
