Page 11 of 35 FirstFirst ... 67891011121314151621 ... LastLast
Results 151 to 165 of 516
  1. #151
    Aha, you know what I suddenly thought the same after I posted it, as blind search would not find those channels either, or manually adding them. The odd thing is though that my Spiderbox 9000 has no problems with those channels using the same LNB wire. Weird. I have 2 Sky HD boxes and now the 5402 coming from the same LNB. The Sky HD box has a replaced PSU.
    I will try what you suggested about making sure the cable is from the inside connector. By this do you mean the one closest to the dish ? Any idea why this may be ? Strange that my Spiderbox used to be fine with the same cable, shame the box broke.
  2. #152
    happy_highlander's Avatar
    Aug 2010
    Default re: 28.2? East Channel List for TM5402, BM7000s, DrHD F15/D15
    If you have a quad lnb you will have two middle ports and two outside ports. Make sure the tm is on one of the middle ones and if it already is put it on an outside 1. As I said my vu works perfect on a port that my tm does not get hd channels with a vertical polarization. You will find all the channels you have listed we be on the vertical.
  3. #153
    Quote Originally Posted by happy_highlander View Post
    I have a Octo LNB as I have 2 Sky HD boxes with 2 inputs each, and a PC satellite card, and the 5402. I think that means I must have 2 sockets free on the LNB.
    If the above option doesn't work, can I get a better LNB or won't that help ?
  4. #154
    Aug 2010
    You can get a better lnb but I think you will find by putting the tm on another output from lnb it will be fine
  5. #155
    Thanks mate. I just turned off all 3 other receivers connected to the same dish and the channels now work. Yet if I turn on just one of the other 3 devices it will cut out. I hope I can move the LNB cables around to get it to work, if not, I am stuffed with a device I can't use as Sky Sports 3 HD is one of the main channels I need.
  6. #156
    Aug 2010
    Is it running on one side of a shotgun cable. If so you may need to get a good quality single coax. I know the have been a couple instances where a bm7000 won't run on shotgun but is fine on single
  7. #157
    Sadly it still isn't working. I went out to the LNB and moved it from port 1 to 5 (see diagram below) then I moved it to port 6, still no luck. Looking at the picture below, which of those 8 sockets do you suggest I use ? 1, 5 and 6 have been tried. As for the type of cable, I am unsure if links are allowed here, but I can link to the exact site I got them from if wanted. It is a 2 lots of 4 cables, they are all single cables, but 4 of them are put within 1 white waterproof protection outer layer. So they are actually all single cables, if that makes sense.
    -DISH-
    1-2-3-4
    5-6-7-8
    Hope the pic above makes sense of what I mean by my LNB layout.
    Thanks again for your help !!
  8. #158
    Aug 2010
    2,3,6 or 7 would be my bet for my first options but i would still try all of them
  9. #159
    Aug 2010
    ok new lists are here and I am aware that sky movies disney will start to broadcast on thursday 28-03-13 and will upload a new list as soon as I can after the broadcast starts but couldn't leave the list another week with espn and the comedy channels missing so here they are
    With adult
    Digital Kaos - Downloads - 28.2 channel list for tm5402/bm7000 adult 23-03-13
    and without
    Digital Kaos - Downloads - 28.2 channel list for tm5402/bm7000 23-03-13
    tp changes to espn, comedy +1, nick jr +1, comedy and +1 ireland, comedy xtra ireland, bet uk, bet +1, cnbc, jewellery channel, ohtv, channel s, ptv prime, channel i, atn bangla, samma tv, islam, sikh channel and on adult list storm, studio 66 3, and studio 66 4. New channels are True entertainment and arise news hd, newly encrypted is geo tv...Sky movies 007/hd are now Modern greats/hd and sky movies oscars/hd are now Showcase/hd....Newly fta is sky news arabia and red light rio has gone
  10. The Following 8 Users Say Thank You to happy_highlander For This Useful Post:
    gamerhariz8 (28th March, 2013), mdt (25th March, 2013), pbahra (24th March, 2013), redrage (28th March, 2013), Rodbouy (28th March, 2013), sat91 (21st April, 2013), Tekken (26th March, 2013), zen1th (26th March, 2013)
  11. #160
    Aug 2010
    new channel lists with sky movies disney channel added and a couple of other minor changes
  12. The Following 15 Users Say Thank You to happy_highlander For This Useful Post:
    apple5002 (18th April, 2013), bluk (30th March, 2013), craggz (1st April, 2013), cybernight (29th March, 2013), gamerhariz8 (28th March, 2013), grizzuk (1st April, 2013), haniballs (29th March, 2013), jon48 (5th April, 2013), kungfunavs (28th March, 2013), Rodbouy (29th March, 2013), sat91 (21st April, 2013), smashes (29th March, 2013), ste2009 (29th March, 2013), Tekken (29th March, 2013), tony_i (29th March, 2013)
  13. #161
    Apr 2013
    Do I need to blind scan my blade box before applying the channel list - I am currently using an old channel list (about 18 months old)
  14. #162
    Aug 2010
    No scan necessary that is the point of the lists. Just install via usb you can overwrite if you wish but I always remove all channels from my tm before installing new list
  15. The Following User Says Thank You to happy_highlander For This Useful Post:
  16. #163
    Mar 2012
    Is there a new list to tale into account the travel and leisure channels change? I read somewhere that there was a new channel to replace some of the old ones.
  17. #164
    digicon's Avatar
    One here HH edited version for NW UK and Irish removed from FAV group : Channel list 28-03-13 NW UK - Downloads - Digital Kaos
  18. The Following User Says Thank You to digicon For This Useful Post:
    nigela (30th April, 2013)
  19. #165
    Aug 2010
    There will be new lists within the next few days. There are quite a few changes within the next few days so once it settles I'll put out the new lists.
  20. The Following 6 Users Say Thank You to happy_highlander For This Useful Post:
    conor2007 (1st May, 2013), grizzuk (30th April, 2013), manxspud (30th April, 2013), nigela (1st May, 2013), togznstyle (1st May, 2013), tony_i (30th April, 2013)
