bump anyone?
bump anyone?
BH 1.6.6.
Best one out them Id say.
Just a heads up there are no cams installed on the blackhole image per say unless you get a preconfigured one that someone has setup with CCcam installed already.
https://hotfile.com/dl/153847224/25c...uplus.zip.html
I cant mind now, Maybe I am getting mixed up with the DM800 ver
If not then just install TSpanel
https://hotfile.com/dl/153847722/82f...ipsel.rar.html
copy the attached file and unzip the file.
use dcc or what ever ftp you want and copy the file to tmp folder.
now use telnet and type the following
pkg install -force-overwrite /tmp/enigma2-plugin-extensions-tspanel_3.6_mipsel.ipk
it will now install the tspanel.
Now goto menu then plugins and tspanel and do a update to 4.9
once thats done you can download cccam from there
what issues you having with the bduk image
Hi, i am using Open Pli image and i think there is cccam, already installed.
bump ?????????
Why cant you just not manually install it?
What have you in in meantime?
The latest VTI 5 image has a server connection for installation of a large number of emus plus lots of other plugins.
IMHO the VTI image is the nicest having tried them all.
I would have thought that in the 8 months it took to bump the thread that the OP would have learned how to manually install cams on an image.
