Looks like you have filed up the flash memory with epg data.
You should still be able to get the box in flash mode. Have a look at the sticky threads (in red) how to flash via browser, probably best to use IE, chrome, firefox wont work for me.
Find the image you want to flash.
Most important make sure it is for your clone dm800se, and very important make sure it is for you sim type.
When you have reflashed the box, and happy with your set up, install the crossepg plugin again, but make sure in the configuration you aim the data to your usb stick and you will be fine mate.
Good luck 003
