Page 79 of 88 FirstFirst ... 29697475767778798081828384 ... LastLast
Results 1,171 to 1,185 of 1319
  1. #1171
    ucokseparoh's Avatar
    Aug 2015
    Indonesia
    x100 OBD
    Add key Toyota Harrier 2005 - Failed.
    Vios 2014 All key lost - Failed. It can't even do remote programming.
  2. #1172
    Apr 2016
    x100 xtool
    vs
    Vag dash can v5.29
    car: Skoda Octavia 2007year
    x100pro
    read pincode OK
    programm key FAIL
    programm remote FAIL
    vag dash can
    read pin code FAIL
    programm key (pin with x100pro) OK
    programm remote OK
    Car VW Polo 2005 year
    x100pro
    read pin code OK
    programm key Fail
    vag dash can
    read pin code OK (same as x100pro)
    programm key OK
  3. The Following User Says Thank You to kluczbum For This Useful Post:
    boskyluki (23rd January, 2017)
  4. #1173
    Apr 2016
    x100pro xtool
    chevrolet KALOS 2007 lost key
    programm key OK
    (you must min 2 keys programmed
    There is no list KALOS
    so
    I chose from the list AVEO
  5. The Following User Says Thank You to kluczbum For This Useful Post:
  6. #1174
    Aug 2015
    Indonesia
    anyone had experience working on Mitsubishi with OBD x100? Specifically Pajero 2014,all keys were lost? Guess i'm f***d up again this time been reading the thread many times it looks like i shall not to put high expectation that it will work on Mitsubishi.
    Anyone know immo location on this car? immobox or ecu? Just in case..
  7. #1175
    stalonerambo
    Guest
    Question
    Quote Originally Posted by ucokseparoh View Post
    anyone had experience working on Mitsubishi with OBD x100? Specifically Pajero 2014,all keys were lost? Guess i'm f***d up again this time been reading the thread many times it looks like i shall not to put high expectation that it will work on Mitsubishi. Anyone know immo location on this car? immobox or ecu? Just in case..
    x100pro on pajero, works/? how did you , work on it, :? i saw a guy , add key on l200 triton 2013, so i think it should work on pajero
  8. #1176
    Aug 2015
    Indonesia
    Hi stalone.. job done in seconds with OBD x100Pro.
    Pajero 2014,all keys lost OK.
  9. The Following User Says Thank You to ucokseparoh For This Useful Post:
  10. #1177
    Feb 2014
    So, some time has passed since both tools were released (Obdstar and Xtool) and I've been wondering if someone has observation over both so he could say if one of them has clear advantages over the other concerning immobilizer functionality and car models support? Until now I can only say that Xtool has updates and odometer correction for much lower price, but I'm not sure about the functionality. Right now they seem equally good(or bad depending on the POV) to me which makes the OBDstar version look like an obsolete tool.
  11. #1178
    lwood's Avatar
    city of angels
    X100Pro
    2014 Nissan Frontier OBD program key OK
    DON'T JUST SAY PRESS IT.....
  12. #1179
    rob h's Avatar
    May 2011
    All Keys lost?
    Is this with the 20 digits pin?
    And how did you get the pin?
    Greetings Robbert
  13. #1180
    lwood's Avatar
    city of angels
    yes all keys lost.
    no 20 digit pin..
    i get pin from auto search. in device. x100pro gives you pin.
  14. The Following 2 Users Say Thank You to lwood For This Useful Post:
    p1et (13th October, 2016), rob h (13th October, 2016)
  15. #1181
    Jun 2013
    Got tip from the Dash area that a new update was out.
    On the Ford immo there is some nice changes.
    Much easier to find your area and model.
    Before US or CN type.
    Now in the new update, a lot of different areas and continents.
  16. The Following User Says Thank You to Weasel3 For This Useful Post:
    Atex31 (22nd October, 2016)
  17. #1182
    dimet's Avatar
    MKD
    Can I read the pin code on peugeot citroen with x100 pro?
    Or I must buy F108 for reading pin code.
  18. #1183
    Hampshire
    Smart 450 2003ish remote programming didn't work, original ad100 worked in seconds , this is the one with no transponder.
  19. #1184
    dimet's Avatar
    MKD
    Quote Originally Posted by dimet View Post
    Nobody knows?
  20. #1185
    Nobody knows?
    By eeprom yes obd no
    Sent from my SM-G935F using Tapatalk
