Page 83 of 88 FirstFirst ... 33737879808182838485868788 LastLast
Results 1,231 to 1,245 of 1319
  1. #1231
    Mar 2015
    UA
    X100Pro pincode be able to read and write the key to Nissan Note 2010 g?
  2. #1232
    HeXeN's Avatar
    Mar 2015
    How to unregister/remove device serial number from my account? In case if we want to add it to other account.
  3. #1233
    Newbie boskyluki's Avatar
    Jan 2017
    VW Tuareg, 2004, 1.9TDi, reed i guess correctly pin but failed programming key. The same pin gave skp900.
  4. #1234
    Hampshire
    Done few Honda civic 46 and 48 id push start, suzuki Alto 2003 with X100 pro, no problem.
  5. The Following User Says Thank You to nazz2 For This Useful Post:
    Faraday (12th February, 2017)
  6. #1235
    DK Veteran labusas's Avatar
    Nov 2010
    Mitsubishi Outlander CAN prox failed to even communicate.
  7. #1236
    Jul 2016
    UK
    Ford Kuga 2012 smart key - programmed the transponder fine vehicle started however no remote/smart key programming.
  8. #1237
    super jumbe's Avatar
    Livingstone
    Quote Originally Posted by nazz2 View Post
    After 2007 to programme Honda you need 7th generation software the last updated softwre on x100 pro is 4th generation on Europe cars, Which year Honda you programmed, from 2007 Honda push start need software from 7th generation software, how did you programme this car when the software not available?
  9. #1238
  10. #1239
    Mar 2011
    Nissan tida 2004 with 46 key x100 read bcm ok but calculator give wrong code use another calculator and program key very fast.
  11. The Following User Says Thank You to fadhle For This Useful Post:
    kluczbum (21st February, 2017)
  12. #1240
    kemaster's Avatar
    BG
    Quote Originally Posted by super jumbe View Post
    I think you mess up immo generations with models generations. For id48 you need 3th gen(there are some exceptions) and for id46 - 4th gen. 2007 is id46 so - 4gen and x100 pro covers it.
  13. The Following User Says Thank You to kemaster For This Useful Post:
    ucokseparoh (16th February, 2017)
  14. #1241
    Aug 2016
    wath is the diference x100pro from obdstar and xtool? it is same tool or have difference obdstar and xtool?
    thank you!
  15. #1242
    Jan 2011
    Im also curious i have x100 from obdstar can i update that device or its not supported
    Sent from my SM-J320FN using Tapatalk
  16. #1243
    Feb 2014
    Xtool and OBDStar are different companies. Both of the X100s are updateable through their manufacturer's website.
    There's an older version of the OBDStar tool which can't be updated, as it's discontinued(I think it was the one without "PRO" in it's name).
    Xtool tool is a little bit cheaper and covers immo+odo functions. Maybe it has a bit smaller coverage catalog and also the catalog is scrambled and harder to find what you're looking for. It is working good though.
    OBDStar tool has 3 versions - only immo, only odo and immo+odo. And the latest release of the immo+odo has also eeprom adapter included. Has a good menu speed with more optimised catalog of the cars. It's a little bit more expensive...
    In the end just get one of them and start working. Differences are not significant.
  17. The Following 2 Users Say Thank You to autoTkey For This Useful Post:
    Ezmony23 (3rd March, 2017), MaxMin (22nd February, 2017)
  18. #1244
    siyadk's Avatar
    Dec 2012
    there are many updates listed in obdstar website for toyota
    http://en.obdstar.com/NewsView.aspx?NId=1347&CId=28
    However there is no new version showing in Obdstar update tool
  19. #1245
    kronk92's Avatar
    Sep 2016
    France, paris
    Xtool X100pro Failed to pull pin vectra c 2003
