Page 85 of 88 FirstFirst ... 3575808182838485868788 LastLast
Results 1,261 to 1,275 of 1319
  1. #1261
    honingkoning's Avatar
    Jun 2010
    Dessert
    Quote Originally Posted by honingkoning View Post
    Nissan Almere 2001, pin calculation by immobox and key programmed in couple of seconds.
    Other garage replaced complete ignition barrel due to key lost, So key is from other car, nats 5.
    Wbr
    Guys Any idea car runs good and after 1 day key is lost again.
    Program again and couple hours later key Dont work anymore.
    Is there something that needs to be done after key learning in Nissan?
    Or should i Try to make new tpx
    Thank you
  2. #1262
    ray-ray's Avatar
    Nov 2009
    10 try's then shuts down, your was no program. Make sure the immo. Light flash 5 time during registion of key.
  3. The Following 2 Users Say Thank You to ray-ray For This Useful Post:
    camelgd (13th March, 2017), Fallen (13th March, 2017)
  4. #1263
    Apr 2010
    i need x100 pinout from machine please
  5. #1264
    super jumbe's Avatar
    Dec 2008
    Livingstone
    Quote Originally Posted by totalkey View Post
    And for what reason?
  6. #1265
    szkeptmen's Avatar
    Jan 2010
    Hungary
    Quote Originally Posted by insomnia2009 View Post
    Which is the best to buy i see x300 aswell but its confusing what to go for whats the best tool and by which company
    Sent from my SM-J320FN using Tapatalk
    X300 PRO3 maybe from Obdstar... full version 579 euro...
    Polak, wegier dwa bratanki i do szabli i do szklanki
  7. #1266
    Mar 2017
    whats is best tool to do toyota smart key al lost??
  8. #1267
    ucokseparoh's Avatar
    Aug 2015
    Indonesia
    ****wrong thread
  9. #1268
    Aug 2010
    Down Under
    Tango just release new module. Job done through obd ... very impressed ... just need to save more money
    Quote Originally Posted by huga46 View Post
  10. The Following User Says Thank You to bigkey For This Useful Post:
    huga46 (3rd April, 2017)
  11. #1269
    Mar 2017
    Default 2003 nissan elgrand
    hello all members please any one can help me immo off my dump?thanks
  12. #1270
    Apr 2016
    uk
    Better use immo thread..
    Inviato dal mio HTC One utilizzando Tapatalk
  13. #1271
    Aug 2010
    Down Under
    With Nissan when program keys, even with wrong pincode, car will start for few times then die.
    So need to make sure immo light is OUT after program key, if immo light still ON then pincode is wrong and key has not been programmed.
    Hope this help
    Thank you
  14. #1272
    Aug 2010
    Down Under
    You are out of luck, I am in the same boat. Just need to buy a new device.
    I bought the X100Pro version, which is cheaper, but x300 (or KeyMaster) seems to be a better choice
    That is my 5 cents but I dont have the x300, so we need opinion of who have the x300 please
    Im also curious i have x100 from obdstar can i update that device or its not supported
  15. #1273
    Jul 2016
    UK
    First Ford that's tripped it up in a while: 2013 Bmax. Seemed to want to work as a fiesta but security failed. Only tried to add the key not all keys lost.
    Chevrolet Spark worked great. (*edit* 2x 8E precoded keys required)
    I see Renault has had an update I'll have to have another play with it on the next one I do.
  16. #1274
    Jan 2017
    USA ����
    Quote Originally Posted by truedetective View Post
    daewoo matiz=chevy spark
  17. #1275
    Jun 2010
    Dessert
    Not a high Clas car But daewoo matiz 2002 key learning Ok.
    You need minimum of 2 keys btw, No code needed.
    Wbr
