Results 1 to 11 of 11
    Question Replacing 5NR.CE1 > 5NR2.C5 ?
    Can i replace a IAW 5NR.CE1-ECU with a 5NR2.C5 ?
    Or does only a 5NR without 2 run in it ?
    Car is a Renault Clio 1,2 16V from 3/2001.
    Renault can only say that their new ones work
    Chris
    Hi friend, i have similar problem, you have solved?
    Is possible replace iaw 5nr.c2 with iaw 5nr2.c5 in clio 1.2?
    Thanks Friend
    May 2013
    Hello, you can replace without problem
  4. The Following 2 Users Say Thank You to dell66 For This Useful Post:
    napster02 (30th October, 2020), pm03 (5th July, 2017)
    Thanks friend, other question: I have to make some changes to the electrical wires or only immo off and plug?
    Thanks friend
    Nov 2012
    greece
    no,only immo off
    Nov 2012
    greece
    sorry immo off with the known procedure described in other post
  8. The Following User Says Thank You to jokas For This Useful Post:
    eiemax (17th September, 2015)
  9. #7
    Ok, thanks friend
  10. #8
    Oct 2017
    Hi friend, i have similar problem, you have solved?Is possible replace iaw 5nr.ce1 with iaw 5nr2.c5 in clio 1.2 16V 3/2001?Thanks Friend
  11. #9
    Member velocimet's Avatar
    Apr 2012
  12. #10
    yes, replace without problem. Immo off and ok
  13. The Following User Says Thank You to eiemax For This Useful Post:
    aurele99 (31st October, 2017)
  14. #11
    Netherlands
    Also replaced a 5NR by a 5NR2 today with the immo file from here, no problem.
