MVBR6, you may now understand, greetings
Can somebody help me with immo problem. I have Sprinter 312d year '97 engine 2.9TD with immo problem. I try everything, some dumps for immo off and at the end I try with Julie emulator but without success.
I find one solution with ECU desolder AN82527, and immo off, not need emuletor... Does somebody try this before?
Thanks in advance!
It's my method, work 100%,if not working ,then write this 24c04...
put july emulator in it
july emulator i find shit.
most a time not working!
Cesarec (4th February, 2018)
I have mercedes E290 1.9td with bosch msa 25.2 ecu (0 281 001 283)
Car not start, and ecu contain cr1 immo emulator, but i think the emulator is dead because no led activity when i power the ecu
If i remove AN82257 CPU from pcb, car will start without emu? The 24c02 (b58 383)is modified for cr1 emu, i mean i don't have original eeprom content).
Second way i must use julie emulator?
any suggestion?
Tom
Your E290 only emulator cr1, if you remove AN82257 CPU from pcb, car will start, but will not work CAN-L/CAN-H and Dash RPM...
julie emulator will work or other needed?
julie work and other ebay cr1 immo work..
thanks, i'll try
Installed julie emulator, sometimes car start sometimes not...
what is the problem?
emulator not good?
Disconnect CAN from WSP?
