DWDJD (29th October, 2023)
I make this jpg for the connection of the board.
Carsoft2003 (12th June, 2013), SALAS (15th March, 2019)
i think that something went wrong with this dump!its a mess!try to read with external eeprom reader
i have readed with an external eeprom reader, xprog, directly desoldering.
anyone to help??
Can anyone give me the calculation for this eeprom?.thanks in advance.
algun paisano que me ayude?
aun estoy probando el algoritmo cuando lo tenga lo posteo aki.
88443km.zip
88443km in the file...
Hi guys English only here if you dont mind it means all can understand cheers
Milesbetteroff here to help
harius thanks for you file, but don't works...still the same km on dash...(
mileage in CJB changed right ... maybe you're wrong to do the procedure with the fuses ...
harius i have found 1 manual for the fuses now here in the forum...i'm making the prodecure now...
I make this prodecure:
1 Take out dash
2 Take out Vecam module (down passeger side,BCM,BSI etc.)
3 Read m35080 from dash and write 0 in lines (see photo)
4 Make connections to modify in vecam module (see photo) 95320
5 Post the dump here in the forum to put real value of km.
6 Read PDF attached to locate the fuses to unplug and plug
7 Important details of pdf:
In the point that you have fitted the dash, bcm + battery
in the car, Leave pressed for 5 seconds,
ONLY, the start button,and the dash and ignition is on.
After, you plug fuses, with the ignition on.
In order, First, plug in rear side the 4 fuses
second plug in the front hood side, first the big 2 fuses
and then, the small fuse.
Now enter to the car and Press Clutch pedal, and
Touch one time the start button, car starts, be careful,
Because if you stop the car, and restart, the old mileage
will return to the dash, and you
should repeat all process again.
Ok, in case of you have switched off IGN, solution is,
car stopped, remove + Battery, and make again fuse
process etc....another detail of pdf...you drive the car on
the way at least 2 km OK, but, don't put VCM LDR
diagnostics because the program make an upload process
that gets config from modules of the car and put old
mileage again. I clear fault codes with Bosch KTS.
Thats all!
Thanks to harius! Good work!
Need help to change km in BCM. Dump with 149448 km and i need 91000 km.
Thank you
