What linux system are you wanting to try?
This site here has links to a lot of Linux distros you should find one to suit your purpose there.
If you don't know which one to try then try one of the popular ones as you will get more support as more people use it.
I have used UBUNTU linux software for years with no problems
Desktop | Ubuntu
Here also is a link to a "10 Best Linux Software OS"
http://geektrio.net/?p=1404
Go to DistroWatch
The best are Ubuntu (which I use), Fedora or Mint, and it really is a matter of preference.
They are different in their own ways, but once you have got to grips with Linux you won't go back.
I have a boot menu so I can log into windows if I want as their are some programmes I use which only run on windows.
I strongly recommend Debian, although is lesser updated, it's very stable !
hi im looking for ClarkConnect do you know where i can fiend it
Here is something
ClarkConnect - Downloads
try #! Linux!
Check out distrowatch.org ... It has loads of distros to choose from...
If your new to linux i would as a few people have said go for Ubuntu.
There are a few versions for different needs eg PC or netbook.
Goto : Home | Ubuntu
Next i would recommend Debian (Ubuntu is actually based on debian)
If you start with a netinstall it will install a minimal install and you can then update from the net
Link : Debian -- Network install from a minimal CD
Hope that helps
If you want to try several different types of linux, most distributions have livecd version som you can test them without the need to install.
Thanks I also found this useful
