suzuki SX4 add key
Results 1 to 11 of 11
    Default suzuki SX4 add key
    Hi guys,
    I am totally new to this one.
    Is it possible to add a key by editing suzuki SX4 dump ?
    Here are the detail:
    Chip: PCF 7936
    ID 46
    Engine ECU: bosch 0 261 S04 530, 33910-54L20
    I dont see any eeprom on engine ecu.
    but on BCM i see 95320.
    Tools i have : zed bull clone, UPA
    Can we do this by reading 95320 from BCM and read key with zed bull and edit dump to add key ?
    igorr's Avatar
    Aug 2010
    no,id46 cant be done like that
    Thanks for the info.
    I think i was living in 4C era....
    i think is time to evaluate tango, tmpro2 and zed bull, get one for good job.
    Apr 2014
    Hi guys I need to do a lost key for one of these. Which tool can get the job done?
    ucokseparoh's Avatar
    Aug 2015
    Indonesia
    depending on the year ad the system.
    below 2012, you can try x100pro.
    2012+ , try F109.
    if you have ZedFull that's even better.
  7. The Following User Says Thank You to ucokseparoh For This Useful Post:
    trinicolin (13th August, 2017)
    Aug 2015
    Indonesia
    .......double post
    Apr 2014
    It is 2010. Tried X100 pro and getting wrong security code after trying 9622. 4229. 0408. 0804.
    Sent from my SM-G930F using Tapatalk
  10. #9
    Jul 2016
    New Zealand
    Zed Full can do car like this in few minutes by OBD without pin.
  11. The Following User Says Thank You to AEMan For This Useful Post:
  12. #10
    Aug 2015
    Indonesia
    try F109
    or get the PIN from online services.
  13. #11
    Apr 2014
    Just updating this tread. Tried Gscan2, F109 and MVP pro and don't know at what point the ecu became bricked. When ahead got a used ecu read tricore eeprom with Fg Galletto and programmed chip with TM 100. Success!!!!!
