Results 16 to 30 of 38
  1. #16
    "I try to recalibrate the dump. First start is very well, but another is also bad as before. Today i will try to install 0.25mm shim in rotor as i read from lucas manual for repair and then new recalibration."
    same problem...........
  2. #17
    Bulgaria
    Today i try with 0.25 mm shim. Engine not start. I removed the new shim and install only original 2 shims. Now car starting very well and working very well. But i have only one fault code (OSM sensor access).
    The engine ecu is repaired by another garage and i think that problem is in him. Maybe they remove eprom and communication between ecu and OSM memory missing. I will open ecu tomorow.
  3. #18
    Bulgaria
    i am shure they are cut some track on pcb or broke some elements
    i have try to calibrate rotor on 3 cars and not have sucsses , so good luck
  4. #19
    Bulgaria
    I have sucess and car working very well.
  5. #20
    Aug 2016
    i have same problem. the car starts only when the MIL goes off. what can i do?
  6. #21
    Junior Member doktorabg's Avatar
    Mar 2014
    Hi to all.
    Next week i will fit a second hand pump (rebuild) in Doblo 1.9 2001 with Lucas Epic pumpe.
    Should I program the pump (93c46) or not to start the car.
    Thanks to all.
    [SIGPIC]
  7. #22
    Dec 2016
    HELLO everyone. I'm not really sure how old this post is but I have the same problem on Fiat Doblo 2004 1.9D (223A6000). The fault codes red with DELPHI diagnostics are P0252, P0254, P0010. Apparantly there is a problem with the pump. The thing is that I'm not really sure what to do with it. Shall I remove it and send it for repair or the problem could be resolved without repairing the whole unit??! Many thanks
  8. #23
    Jan 2017
    Czech Republic
    Hello
    I have same problem with fiat doblo. Engine wont start without full throttle and hold idle. Diagnostic show P0252. I try calibrate OSM sensor. After calibration, 1st cold start is same. On the 2nd start, car idling and react on accelerator pedal, but the idle is erratic. Now diagnostic show errors P0252 and P1607.
    Thanks for any helpful replies.
  9. #24
    cubica1's Avatar
    Feb 2012
    Serbia
    better results u'll get if solder hole electronics of rotor, recalibrate eeprom and soldering ecu conector points (behind sticker).
    rgds,
    cuby
  10. The Following User Says Thank You to cubica1 For This Useful Post:
    audiopoint (17th April, 2018)
  11. #25
    Sep 2016
    Romania
    please could help me with change of position of rotor in memory 93C46 ?
    I been trying already few to repair it by using mechanics method but without any luck
    https://mega.nz/#!sVRzUKjB!x81QPEr2CHWfgDSOXP_XuZUVGTcmaI8CPMqQGac zlbo
    BEST OFF ...
  12. #26
    cubica1's Avatar
    Feb 2012
    Serbia
    recalibrated,
    rgds,
    cuby
  13. The Following User Says Thank You to cubica1 For This Useful Post:
    lordraidem (27th January, 2021)
  14. #27
    Bllinda's Avatar
    Baltic
    Lightbulb epic.2. ( find .... Lucas EPIC I. II and III )
    What mechanics techniques did you use?What data do you need to change?
    Quote Originally Posted by mccmman View Post
    today
    A topic that interests me
  15. #28
    cubica1's Avatar
    Feb 2012
    Serbia
    pls pass friend for epic 2
    thx,
    cuby
  16. #29
    Apr 2018
    Quote Originally Posted by cubica1 View Post
    thx,
    cuby
    And me too. Please.
  17. #30
    Sep 2011
    help pass pls thanks
