I have made 4c data to eh2 and works on clone .
Have made 4D70 to tpx2 and is working with clone zed.
(But i thought everybody knows how to do this with clone Zed)
hi, excellent post, I saw your video and I thought to ask if it works to unlock remote control id 46 in psa group? through time I have accumulated several of these that were miscoded and would be very nice to put them to work again, I would like to know your thoughts. if what I'm asking is stupid, I apologize, just when I see a person like you who share their skills here, openly only makes me wonder, hope the automatic translator does not change the words in my original language. regards
I already answered in personal messages much. I will answer once again for all.
I don't sell the program. When the program which I already laid out will be tested, I will spread the program with new possibilities.
Agree, what sense to have the full version with all makers if she badly writes down and read transponder.
PierreTheron (18th August, 2021)
Wonder how u can laid it out or make it better as i know all clone used a cheap components and its firm/soft ware was unstable......by the way do you have datasheet for pcf7991at abic ic used in zb clone? (i only got that 2 pages pdf)
hoangtu (4th January, 2016)
your can precoding a chip with this dump????
thank you
P i have a zed bull clone 5.0 with 5.8 soft
if I have the current version of the file "transponder.mdb" I can use all the features of the original zed-bull? tpx1, and tpx2 tpx3?
The file transponder.mdb doesn't add any possibilities, it is intended for display what transponder are applied in a car.
Sierra your software is looking good when will you be releasing the full version.
:thumbup:
Sent from my Galaxy Nexus using Tapatalk 2
few suggestions;
transponder production - I'm sure theres enough people here that can PM some help. Would be good to get vauxhall pcf7936 precoded which I believe the miraclone does.
Also on fiat id46 system would be good to enable 'create image file' as the original I believe still needs coding after. I know someone here has wrote they write the key bytes in manually.
To add new possibilities it it is good
But I first of all want to correct mistakes in that that already made.
Now some people from different forums check the program.
paul_12345, if you want to take part in program testing, write to me to PM
In the program likely there are a lot of mistakes, I can't check everything.
