Results 1 to 7 of 7
    Sep 2009
    Default mercedes w202 220CDI valve y75 error P1622
    hi
    car is w202 220cdi 1999
    ecu bosch 0281001816 A 025 545 72 32
    have this error Code is P1622 "Fuel Shut Off Solenoid Defective" also has Y75 in the description.
    installation was short, I repair
    but now not having the valve 12v.
    problem comes from the ecu, anyone know which component controls the valve.
    thanks for any help.
    leandroks's Avatar
    Feb 2010
    Brazil
    The positive on the valca comes from the fuse box, the ecu control it via negatives pulses, so have a look on the fuse box there is a big chance your problem is there... cheers
    Sep 2009
    Question
    Quote Originally Posted by leandroks View Post
    Wires come direct from Ecu,conector 4, wire 25 and wire 35
    Go to valve Y75
    Shmortz's Avatar
    Apr 2010
    in the middle of nowhere
    you will need to replace BOSCH 30403 - ECU driver
    Sep 2009
    Quote Originally Posted by Shmortz View Post
    In Ecu i see Bosch 30382,
    Bosch 30381 is compatible?
    DK Veteran rachmach's Avatar
    Jan 2011
    Workshop
    i had same problem i was replace ehe ecu
    Apr 2018
    Germany
    Default Bosch 0 281 001 987 ELAB
    I`ve got the same Problem with the in Head named Part. Is it the same proceder to fix it?
