file with ff
file with ff
Don?t understand what you say
Tested solution.
br
Thanks Morfej, I test the archive as soon as posible because the car is being repaired in the garage.
I make my own clear with carprog clone, but the carprog don?t have 608673700, it have 608673600.
I think that the solution must be equal but my clear file have only 2 changes respect to crash file.
I upload my clear file and check the changes, they are in the 0760h and 0762h.
I?ll test the two files, mine and yours and post results.
Pass in PM
Mine is already tested... I actually don't need feedback ... and I won't be surprised if carprog made it wrong.
Have you notice versions v10,v11,v12,v13 ... or that details are too much
maybe works ,check it.
regards
Than diagnose it on table ... with fiatecuscan for example.
br
Hi morfej, sorry for delayed but I can?t test the unit before.
I tested the 3 files, mine, yours and the kolocar file. All files works ok, I don?t understand, because the changes are very diferents. I check the unit in car, the light goes off and check with a diag machine and no have any errors.
The carprog change is very easy, only two bytes, but in your file and in kolocar file this 2 bytes aren?t changed.
I don?t understand this.
Same solution as before.
please cod for clear damp doblo. Thanks
hello, clear adress: 4D0 to 72F -FF and crash is cleared:-)
Hi. Please help clear crash data!
Fiat doblo
608 67 37 00 autoliv
I need tested solution. thx
auto80 (8th December, 2014)
