Go to downloads on this website, click search and type the word Engineer Sofware, Scroll down till you see Epison SX125 Waste ink reset and download that program Then ensure you have WINRAR or Zip ,IF you dont have still download it on this website click search and type the word Winrar. After that Connect the Supported Printer Via USB to Computer Open Engineer Sofware using Winrar or Zip or other Double click AdjProg.exe If Prompted by Antivirus it does trust publisher Allow it. Click Accept Select Model as: Epson TX121 DEst: ESP Language English Port: Auto Selection Then go to click Particular Adjustment Mode Go to Maintance section and click Waste ink pad Counter Tick Mainpad Counter and FL bOX coUNTER Click Check. Your are almost through now, Tick Mainpad Counter and FL bOX coUNTER again then click Initialization Your Printer is now reset Switch your Printer off and on again. You can Tick Mainpad Counter and FL bOX coUNTER Click Check again to confirm you have reset your printer and it should now read 0 % No other activity is done ,Exit this software now. i shal get back to this website after 48hours till you reply. give me your remarks. good luck
Then
After that
Click Accept
DEst: ESP
Language English
FL bOX coUNTER
Click Check.
FL bOX coUNTER
read 0 %
good luck
Indig0 (7th December, 2023)
