Results 1 to 12 of 12
    Post Fiat Stilo electronic key code
    Hello
    Can someone please calculate electronic code (pin code)
    from dump from body(bsi)
    it`s motorola 9s12dg256 (my zedbull was broke)
    i read motorola with upa
    regards
    Jan 2009
    Earth
    Default code
    your code is 85242
    Thanks Dmythross
    it`s work and it was very fast reply
    regards
    Newbie sparky1972's Avatar
    Dec 2012
    Halifax
    can you do code from vin no????
    Dec 2017
    What is needed to generate electronic code for my fiat stilo?
    Thank you in advance for your answer.
    newone's Avatar
    Oct 2016
    you must post dump from bsi
  7. The Following User Says Thank You to newone For This Useful Post:
    flachi88 (16th December, 2017)
    Dec 2017
    How do I get dump file from bsi?
    I am using MultiEcuScan for my car.
    Can it be done with it or i need something else?
    Sorry, but I'm not an expert.
    rob h's Avatar
    May 2011
    Depending what type of bsi you have,
    Some have a eeprom, others processors like motorola.
    You will need to disconnect batery, remove bsi under dash.
    Then dissamble the bsi, and read the correct eeprom or processor.
    Reading and writing can then be done, with a Chinese upa or xprog programmer.
    Some tools like IO Terminal, Smok or Avdi can read these files by obd.
  10. The Following User Says Thank You to rob h For This Useful Post:
  11. #9
    Dec 2017
    Thank you very much for information.
    I'll try to read with those tools.
  12. #10
    Dec 2017
    Me again, I'm probably boring...
    I can't use any of those tools ( if I downloaded them correctly ), I'm always getting error FTD2xx.dll file missing.
    I'm using ELM 327.
    Can any of these pictures be helpful or DUMP from BSI is only thing that can help?
  13. #11
    Aug 2015
    Quote Originally Posted by flachi88 View Post
    I'm using ELM 327.
    You can't use these softwares with cheap ELM cable, you need their hardware tools that are costing at least couple of thousand $ and intended for proffessonal use.
    For you cheapest option would be to go to some independed locksmith who has propper tools.
    edit: and i am talking about tools someone earlier mentioned as avdi, smok.... not multiecuscan which is only for diagnostics...
  14. The Following User Says Thank You to dtip For This Useful Post:
    euroscan1 (18th December, 2017)
  15. #12
    Dec 2017
    @dtip
    I see you are from Serbia, can you do reading and calculating for me, and how much does it cost?
    I can't find is there an option to send you personal message.
