your code is 85242
your code is 85242
Thanks Dmythross
it`s work and it was very fast reply
regards
can you do code from vin no????
Hello,
What is needed to generate electronic code for my fiat stilo?
Thank you in advance for your answer.
you must post dump from bsi
flachi88 (16th December, 2017)
How do I get dump file from bsi?
I am using MultiEcuScan for my car.
Can it be done with it or i need something else?
Sorry, but I'm not an expert.
Depending what type of bsi you have,
Some have a eeprom, others processors like motorola.
You will need to disconnect batery, remove bsi under dash.
Then dissamble the bsi, and read the correct eeprom or processor.
Reading and writing can then be done, with a Chinese upa or xprog programmer.
Some tools like IO Terminal, Smok or Avdi can read these files by obd.
Thank you very much for information.
I'll try to read with those tools.
Me again, I'm probably boring...
I can't use any of those tools ( if I downloaded them correctly ), I'm always getting error FTD2xx.dll file missing.
I'm using ELM 327.
Can any of these pictures be helpful or DUMP from BSI is only thing that can help?
You can't use these softwares with cheap ELM cable, you need their hardware tools that are costing at least couple of thousand $ and intended for proffessonal use.
For you cheapest option would be to go to some independed locksmith who has propper tools.
edit: and i am talking about tools someone earlier mentioned as avdi, smok.... not multiecuscan which is only for diagnostics...
euroscan1 (18th December, 2017)
@dtip
I see you are from Serbia, can you do reading and calculating for me, and how much does it cost?
I can't find is there an option to send you personal message.
