Results 1 to 5 of 5
    somewhere around here
    Default 2.0 TDI CR VAG turbo actuator setup procedure
    Hi, does anyone have any info on setting up the turbo actuator on the 2.0 CR TDI? We have done one recently, but we're getting a lot of smoke and knocking under hard acceleration from say 1200rpm. Low throttle at low revs or hard at 2000 and higher feels all good. Just wondering whether there is anything tricky in the procedure or whether it is more of an EGR issue. thanks
    looks like there isn't much info out there about it :-(
    Apr 2017
    Quote Originally Posted by chris_e36_328 View Post
    Did you solve this problem, i have the same here?
    Dec 2013
    Bosna i Hercegovina
    Friend authorized services have tool for adjusting the turbo actuator. allegedly without this tool can not be set new turbo actuator
    Oct 2012
    Here PDF manual
  6. The Following 10 Users Say Thank You to incc For This Useful Post:
    angelx431 (10th July, 2022), bronec10 (14th July, 2018), cosmin cl (6th February, 2018), dardoelectro (2nd June, 2023), glockandor (4th March, 2018), Pietrek (10th January, 2018), Qwarz (1st August, 2018), replay (8th September, 2017), zar0079 (10th November, 2017), zizotronic (13th March, 2018)
