Page 1 of 11 123456 ... LastLast
Results 1 to 15 of 159
Hybrid View
    impactops's Avatar
    Default DAS Smart Tan 5.2012 and 7.2012
    Extract file from Archive into F:\Programme\DAS\smart, make sure you backup the original.
    No code needed to be entered, just press F2
    It should work for all codes, i have only tested in sim mode
    Since the DLL has not changed with 7.2012, it also works with that version
    Pass:Qutomotive
    Regards
    Impactops
    Last edited by impactops; 3rd August, 2012 at 03:15 AM. Reason: Also works with 7.2012
  2. The Following 25 Users Say Thank You to impactops For This Useful Post:
    agan4ik (20th August, 2014), autodigitec (24th July, 2014), beongo (28th September, 2013), chulin (26th November, 2015), crappy44 (11th December, 2015), dar7914 (29th October, 2018), Darylwatkins (2nd August, 2017), dvdpgn (1st September, 2016), EagleOne2010 (10th September, 2013), Harlequin69 (20th January, 2018), JCoquenao (26th February, 2016), jimis (6th September, 2013), king kong (26th January, 2014), ktuning (15th October, 2018), Louislesinge (5th July, 2023), mcgustoo (6th September, 2013), nexia201 (16th May, 2016), Raod (4th September, 2017), rmkeizer (9th January, 2016), roma5000 (22nd November, 2017), t1tan1 (25th November, 2013), Wickybe (22nd August, 2016), xlb450 (8th August, 2023), yutaka yoshida (3rd September, 2022)
  3. #2
    Jan 2009
    not work, csd dll error
    DK Veteran wsc's Avatar
    Aug 2009
    GR
    Nop, wrong m8 ziko, the dll is working BUT it cant open the channel for key programming (thats i tested for)
    I mean that does not going to the procedure:"unlocking the unit please wait... etc.etc..."
    Smart car engineer ,
    impactops's Avatar
    Quote Originally Posted by wsc View Post
    If you can be more specific, if i don't see the error in sim mode then i won't be able to fix it.If you can post or pm vin of vehicle used, also i found that with the old smart tan calc and no mods the codes generated for "Program key Transpoder" are accepted by das 5.2012.
    If you want to solve it also provide pics
    Regards
    Impactops
  6. #5
    Aug 2009
    GR
    here is some photos from the procedure
    Is missing one step from the procedure,the second step
  7. #6
    impactops's Avatar
    As you can see the from the picture below, using the same vin number as the one displayed in your pics in sim mode, it completed the function
    I also tested the following for the same vin
    Activation of function "SOFTOUCH"
    Activation of function "Steering wheel gearshift"
    Activation of function "Cruise control"
    they all completed succesfully
    Regards
    Impactops
  8. #7
    Aug 2009
    GR
    the procedure is completed mate but without the second step(for the key learning that i tested) cant completed correct, the led does not flashing and the key not accepted
    I did not tested other functions
  9. #8
    impactops's Avatar
    How am i going to see that LED in sim mode?
    You need to explain the 2nd pic more thoroughly if you can, does it wait for you to press F3 cause from your pic it looks like it has been pressed.Can you test the other smart tan functions?
    can you also make video of procedure?
    Regards
    Impactops
  10. #9
    Aug 2009
    GR
    i know mate that you cant see the led if you have not a car .....
    i just told you that the procedure is incomplete
    Well: after the second pic and then ignition off a LED- switch which is located on "cockpit" is flashing and prepares the unit to accept the key by pressing twice the lock button...
    Thats all the procedure...
    I will test and other functions and let you know,maybe and in Day
  11. The Following User Says Thank You to wsc For This Useful Post:
    Greck81uk (25th August, 2016)
  12. #10
    Aug 2009
    GR
    Hello again
    Tested tempomat-> ok
    Tested steering gear shift-> ok
    Tested softouch -> ok
    Tested again key learning-> not ok
  13. #11
    impactops's Avatar
    Hello again
    Thanks for the testing WSC.
    I believe there are other issues in play here, if i try to "Add or remove equipment code" just by pressing F2 the vin number displayed on the top right hand corner is altered.If it writes this to the vehicle/module then you will have a severe problem.i have made changes to the key learning section which i believe should work, but since the functions that are not working at the moment rely on information from the code entered it may do more harm than good.
    If you want to try it either way just tell me and i will post it, also the mod below appears to still work with 5.2012
    http://www.digital-kaos.co.uk/forums...2011-a-202960/
    Regards
    Impactops
  14. #12
    Moderator
    PremierD's Avatar
    Jun 2009
    2 out of 3.. (for now) is better than a poke in the eye with a sharp stick mate ..
  15. #13
    Aug 2009
    GR
    i have not problem mate let me know and i will test it as soon as possible
  16. #14
    Apr 2023
    THX for posting this here
  17. #15
    impactops's Avatar
    I have modified the key Learning routine, use at own risk
    Pass:Qutomotive
    Regards
    Impactops
    Last edited by impactops; 3rd August, 2012 at 03:16 AM. Reason: Also Works with 7.2012
  18. The Following 27 Users Say Thank You to impactops For This Useful Post:
    alelaskaris (12th January, 2024), angel22272 (17th February, 2020), baltazar3 (18th March, 2016), benojoel (22nd July, 2020), cdex (10th December, 2013), chanodaniels (21st April, 2017), Dan114 (29th February, 2016), elephantul (28th July, 2013), EwellG (4th November, 2013), fpschris (30th May, 2020), giuseppe1374 (15th December, 2013), hatimtai (14th August, 2016), Idy (18th March, 2024), joebree (26th February, 2018), kuni92 (22nd November, 2015), mcgustoo (6th September, 2013), nikolakismb (18th August, 2016), olegario (8th May, 2023), roadsterptpt (1st September, 2016), rudi888 (31st May, 2022), RUSLAUTOEL (22nd March, 2018), speedservice (30th August, 2018), tadin (8th February, 2019), teris (23rd November, 2013), terymech (13th June, 2018), tommet (2nd January, 2016)
