Page 10 of 11 FirstFirst ... 567891011 LastLast
Results 136 to 150 of 159
  1. #136
    Jul 2018
    Hi All
    I have had a look through the thread and I cant for the answer I am looking for, so Can any one confirm that the file works on a 452 with a MB Star C3 ?
  2. #137
    Jul 2018
    Hello everyone can send me the file?
  3. #138
    Aug 2018
    Is this file still available?
  4. #139
    Mar 2019
    Dear Impactops. I downloaded the file. Requires a password to extract.
  5. #140
    Feb 2013
    Hi all,
    I also downloaded the file but for me the password wont work, any ideas?
    cheers
  6. #141
    impactops's Avatar
    Has this mod been tested on newer versions of Das?
    Regards
    Impactops
  7. #142
    May 2019
    tested on 2014/09 stil works to teachin key with the v2 file.
    Best regards,
    Jero
  8. #143
    May 2019
    does it worc in manual mode? when i write codes by my hand on keyboard?
  9. #144
    Jun 2019
    Quote Originally Posted by impactops View Post
    Regards
    Impactops
    The latest I have used it is 09.2016
  10. #145
    didi_du_93000's Avatar
    Dec 2009
    France Paris
    Hello, where you find learn key in SAM?
    I haven't find.
    Regards,
  11. #146
    Mar 2020
    Hi, all coding worked on DAS2010, about 2020 stopped working, do anyone have the same problem?
  12. #147
    Apr 2020
    weston super mare
    Quote Originally Posted by jirka B View Post
    im going to try it on 2012 software
  13. #148
    Oct 2020
    thanks, hope this works
  14. #149
    Nov 2020
    Thank you~
    This is a big challenge
    You're great
  15. #150
    Apr 2021
    Thanks for the work you must have put into this.
    I assume the "7.2012" is the DAS release date, in which case the mod works on 11.2012 for key coding.
    I have a lot of experience of the systems outside the "black Boxes" but not what goes on inside.
    Thanks again
    Ah, spoke too soon.
    I have the same problem as WSC (page 1)
    The Immobiliser LED should come on constantly and flash off for each key programmed in.Imobiliser LED.JPG
    Mine doesn't even enter the LED on stage and I'm using the V2 version.
    I'd be interested to hear from WSC what, if anything, he did different.
    Any advice will be appreciated.
    Also, does anyone have an idea or can explain the reason for the "No log file for code numbers" means with regard to the software of the SAM/ECU immobiliser?
    The SAM was changed from a V007 (I've coded keys in no problem) to a V011 unit.
    Again any help will be appreciated.
  16. The Following User Says Thank You to Ulysses1203 For This Useful Post:
    Locteau (20th October, 2021)
