Page 363 of 462 FirstFirst ... 263313353358359360361362363364365366367368373413 ... LastLast
Results 5,431 to 5,445 of 6927
  1. #5431
    Nov 2012
    Croatia
    Today try mondeo keyless,same car i did past 6 month,now try write forward mileage but instead 541767 dash show 17450,try twice, only different is sw version ,in past was 4.88 and now 4.94 maide by Cardig,
    anyone do this dash manualy
  2. #5432
    Nov 2012
    Croatia
    update,
    if i put 535425 have 11137,
    541767 have 17479,
    17479 have 17479,
    put old have old on display,any coment
  3. #5433
    Quote Originally Posted by ikara View Post
    update,
    541767 have 17479,
    17479 have 17479,
    Take dash out and program 24c16 directly it will save u time and aggrovation
  4. #5434
    Nov 2012
    Croatia
    Quote Originally Posted by javyb View Post
    ok,but digi say after do eprom to conect digi again and put new km,is possible calc eprom without digi again and more than 300 000
  5. #5435
    Mar 2015
    Hallo My friend there is a special procudure for the keyless go mondeo read the ~~~~ing manual. if you dont have just ask i wil send you the pdf
  6. #5436
    Jan 2016
    Senegal
    Hi. Need help about my digiwigi3. After di-soldering chip 93C76 (dash kangoo 2009) cannot download it on pc with eetools2. I can download all other file but not this one. I can read it on digi3 but not download. Is it possible to save my dump without corruption. Thanks.
  7. #5437
    Mar 2015
    Quote Originally Posted by ndjine2005 View Post
    you dont need to upload file you can make correction directly or do you want to do it with tachosoft ?
  8. #5438
    Jan 2016
    Senegal
    my problem is i cannot read twice the chip. No way to read or write it. Want to do with tachosoft, may change the chip with new one? mine is 93c76 wp. New one without wp will ok? thanks.
  9. #5439
    Mar 2015
    i had some issues with it in de past even if it was wp i could write a new vakue like the toyota aygo iy reads strange value and after correction stil had a strange value but once in the car was goed i dont say you have to do it that way but if there is no risk just try i think it wil be ok
  10. #5440
    claudio35's Avatar
    Chile
    Hyundai Terracan w nec, adapter st59, 100% ok, working
  11. #5441
    Mar 2015
    Quote Originally Posted by claudio35 View Post
    Does the ST 59 works with all digis or only the one deliverred with it and wjere it can be ordered?
    Thanx
  12. #5442
    claudio35's Avatar
    Chile
    Quote Originally Posted by garabounga View Post
    Thanx
    http://www.uobd2.net/wholesale/st59-...digiprog3.html
  13. #5443
    Nov 2012
    Croatia
    i check manual,no problem in procedure,but mileage want go over 500 000,
  14. #5444
    Mar 2015
    Hmmmmm if it a keyless go you need to program first with the key away from the car did u deed that ?
  15. #5445
    Nov 2012
    Croatia
    If the key away than no ignotion,procedure is
    Ignition on
    Put zero
    Turn off ignition
    Put the key away of car 10 min
    Acctualy 10 min need dash to go sleep
    Start the car and off
    Wait 10 min again,with the key away of car
    Ignition on and mileage what you want,short after mileage shown ignition off and away the key for 10 min
