hey nicolas why except polo 2012 ?
ive try'd this car today , and i have now a error message in the cluster..
using digipro3
what happend ? and what can i do to fix this
using digipro3
Digi 4.94 has a polo johnson controlls bug. You can only solve this to make a new adjustment with another tool. For example smok.
hey peter ! :P NL gaat me makkelijker af ! wat moet ik doen ?
What do I need to choose in te Menu because I can't find the eeprom chip 93s59
Hello all Guys,im request for a little helps millage corrector on bmw E91 year 10/2009.
Can you anything tell me isit posible with Tool clones China Digiprog3 yanuha 4.94 doit this job good?
And we’ll becoming a good tread for working I’m very happy;-)?
Thanks in advance 1XXXXX
Gesendet von iPhone mit Tapatalk
Hello thanks for your help.
And Digiprog3 not try on dashboard?
No way?
moffo (16th December, 2017)
O.k
For the dashboard you will need to replace the 35080 / 080dwq which you can do with the digiprog.. but nicer to do with a proper eeprom programmer, thst way you know you've programmed it correctly.. for the cas unit I would suggest r260 too..
Sent from my SM-G935F using Tapatalk
Is possible to read/write 24c64 "atmel"?
Exacly AT64A
Maybe with SSOP8 or "pogo adapter"?
Someone did try with DP3?
Wysłane z mojego K920 (CN) przy użyciu Tapatalka
