Page 420 of 462 FirstFirst ... 320370410415416417418419420421422423424425430 ... LastLast
Results 6,286 to 6,300 of 6917
  1. #6286
    Mar 2012
    Quote Originally Posted by Music73 View Post
    For the dashboard you will need to replace the 35080 / 080dwq which you can do with the digiprog.. but nicer to do with a proper eeprom programmer, thst way you know you've programmed it correctly.. for the cas unit I would suggest r260 too..
    Sent from my SM-G935F using Tapatalk
    Hello Music73 can you tell me instructions please for this job?
    I have search in internet but not find good tutorials:-(
    Gesendet von iPhone mit Tapatalk
  2. #6287
    Jun 2011
    Northamptonshire, UK
    Quote Originally Posted by moffo View Post
    Its not too difficult..
    strip dashboard down.. Remove 080DWQ read with eeprom programmer (as a 35080) like xprog or upa.. save image mod with some program like nyo4.. write modes image to a new 080DWQ.. Solder newly programmed eeprom back to dash and reassemble.. don't fit back to the car until the cas unit is done.. Cas unit.. follow instructions your type cas unit.. these come with the r260.. Will require soldering to some fairly small solder points... read.. mod.. write.. finally but everything back together.. and you should be good to go...
  3. #6288
    Mar 2012
    O.k Unterstand!
    But i don’t Know my EEPROM is a 35080 and i Must buy a 080DWQ not a 35080 EEPROM?
    A another request,The cas must Solder no via OBD2 trying?
    Tranks
  4. The Following User Says Thank You to moffo For This Useful Post:
    gonzcaal (3rd January, 2018)
  5. #6289
    Jun 2011
    Newer 35080's aren't erasable without a specialist programmer and have been superseded with 080DWQ's... so if you haven't got a 35080v3 then your most likely gonna have to replace it... and new replacements are now 080DWQ..
    Sent from my iPad using Tapatalk Pro
  6. The Following User Says Thank You to Music73 For This Useful Post:
    moffo (17th December, 2017)
  7. #6290
    antenor's Avatar
    Here
    Hallo can you please send me instructions for this job Music73
    https://www.youtube.com/watch?v=_j4biUzI570&t=13s
    If i help, d'not forget to press thank button!!
  8. #6291
    Mar 2012
    O.k thank you Music73 i buy new EEPROM and try this!
  9. #6292
    Dec 2017
    Hello there.
    I tried to correct millage in a 2013 Audi RS4, digiprog starts the process correctly, then asks for new millage, I enter the new millage and then it starts to "VERIFY"... The thing is that a count starts and takes FOREVER. 1..2..3.. I waited for over 25 minutes, cant remember if it went to 30.000 or higher... The thing is that it never finished, dashboard never turned off or something. Am I doing something wrong?
    Best regards
    John
  10. #6293
    Dec 2017
    Wow... great!!
  11. #6294
    Dec 2017
    Normally it counts 10. 20. 30 until 11.000-13.000
    Yours says Verify. That's something different I think. So probably it doesn't support dash rs4.
    Try another tool.
  12. #6295
    Dec 2017
    Quote Originally Posted by Pjotter83 View Post
    Try another tool.
    Thank you very much!
    Yes you are right, count goes 10...20... (not 1...2...)
    As far as I know, RS4 dashboard is nothing different from an A4 dash.
    What other "affordable" tool could I use?
    Thanks in advance
  13. #6296
    Nicolas9's Avatar
    Feb 2017
    Aruba
    I was thinking about obdstar. But they don't even have normal A4 listed.
    I wouldn't know. Maybe fvdi..
  14. #6297
    Dec 2017
    Quote Originally Posted by Nicolas9 View Post
    thanks, I will try to find out.
    Regards!
  15. #6298
    Quote Originally Posted by wernerpfalz View Post
    Wow... great!!
    There is a 'Thanks' button, please use it if you find a post helpful.
  16. #6299
    Mar 2015
    Quote Originally Posted by alperstyl View Post
    can u help me ?
    Try again with digi 4.88
  17. #6300
    May 2017
    argentina
    digiprog3 not work in renault clio mio 2015 argentina
  18. The Following User Says Thank You to TOPITOAUDIOCAR For This Useful Post:
    DARFVADER (29th December, 2017)
