Page 430 of 462 FirstFirst ... 330380420425426427428429430431432433434435440 ... LastLast
Results 6,436 to 6,450 of 6917
  1. #6436
    Nicolas9's Avatar
    Feb 2017
    Aruba
    vw beetle 1998. USA miles.
    read with xtool ok . write km not ok.
    use digiprog.
    menu beetle -2011 -> diag
    first read.. it shows '?'
    then it asks old mileage. I enter old miles
    then it ask new mileage.
    write new mileage ok!
  2. #6437
    skens's Avatar
    Zagreb,Croatia
    hi
    POLO JC 2010 obd2 , read km ok after write km ,error
    regards
    Please dear members push the button thanks and reputation button(stars)
    do you need help? fill it in !!!
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    ECU type and number:
    Memories :
    https://www.digital-kaos.co.uk/forum...63#post1660863
  3. #6438
    Nov 2016
    Hello anyone has free tokens options for digimaster 3 or a software for unlimited token for Digimaster 3 ?
  4. #6439
    Nicolas9's Avatar
    Feb 2017
    Aruba
    w204 facelift.
    option Ezs.
    old mileage jump back
  5. #6440
    May 2018
    can Digiprog 3 works for BMW X5 E70 - 2013 to correct mileage ? with R270 for CAS ?
  6. #6441
    Dec 2016
    Quote Originally Posted by neosez View Post
    It should, I made with it E83 X3 from 2010. Should be the same.
    >>Genuine Winols, Swiftec, Ktag, Flex, x17<<
    >Diagnostic, Chiptuning, Dashbord<
  7. #6442
    May 2018
    Quote Originally Posted by kubuswujo View Post
    thanks for quick response.
    Correct me if i'm wrong - the procedure.
    So the sequences will be first remove CAS to check the microcontroller mask type than install back, connect Digiprog via obd and update mileage. Than remove the Cluster find EEPROM connect it with R270 and update Mileage than install cluster back.
    at the end erase DTC error using Digiprog
  8. #6443
    galaxy0634's Avatar
    Jan 2018
    Namek planet
    hello tell me bro why digiprog 4.94 cant change mileage of tiguan 2013 in dsg gearbox
  9. #6444
    Dec 2016
    I take down the CAS and TAcho have made tacho with rr270 and then made CAS with Digiprog. You can do also EWS if you want. then you have 100% milage changed.
    After all instaled i have removed all faults with ISTA. You can use other interface to remove DTC.
    Nov every DTC is with new milage
  10. #6445
    Nicolas9's Avatar
    Feb 2017
    Aruba
    i did polo 2012 with digiprog. it gave error in dash.
    tried to disconnect battery didn't help. (which battery-pole is best to disconnect? min or plus or both?)
    then I tried xtool using the JC option (it was jc cluster). but can't connect. it dont change.
    thnx
  11. #6446
    Nicolas9's Avatar
    Feb 2017
    Aruba
    vw beetle 2013.
    digiprog obd not ok.
    (then try x-tool, also not ok. must change manually, soldering)
  12. #6447
    Sep 2015
    It's ok, to see new mileage in dash, but still far far away from 100% job.
    What about EGS, TPMS, engine ECU, xdrive box, battery replacement, other locations in CAS, AIF ...
    You need AVDI or BMW Explorer to do this properly.
  13. #6448
    Nicolas9's Avatar
    Feb 2017
    Aruba
    rs4 2006. dont work
  14. #6449
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    enigma provides a solution dash diagnostic for new beetle NEC 95320 see pdf attached
    'If I helped, please click Thanks +Reputation.. !'
  15. The Following User Says Thank You to rtbdiagnostic For This Useful Post:
    Nicolas9 (18th May, 2018)
  16. #6450
    Quote Originally Posted by Nicolas9 View Post
    vw beetle 2013.
    how you made manually is it magneti marelli with 95320?
