Page 436 of 462 FirstFirst ... 336386426431432433434435436437438439440441446 ... LastLast
Results 6,526 to 6,540 of 6917
  1. #6526
    Sep 2018
    Okey since nobody had any clue i come with a update, the cluster was defect, so my question now is did the digiprog kill it? Why do they kill volvo clusters?
  2. #6527
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by Alexxelax View Post
    Some of the leads are not wired correctly so could be that or used the wrong cable
  3. The Following User Says Thank You to teerak2uk For This Useful Post:
    Alexxelax (25th September, 2018)
  4. #6528
    Sep 2018
    Quote Originally Posted by teerak2uk View Post
    Thanks for replying.
    From the beginning i may have soldered wrong, but used the 51 dongle. Will some faulty soldered wires kill the cluster instantly? And is it because of that some say that not use digiprog on volvo cluster?
    I am going to buy another cluster to try on again, so all tips and advises will be appreciated.
  5. #6529
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Soldering incorrectly can kill it and I've done a few older Volvo's without a problem just check connection s inside cable 25 way plug
  6. #6530
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    PLUG 51 has a SUPPLY 12V and PLUG 48 has a SUPLY 5VOLTS... maybe tha dash was dead you did solder wrong suply voltage which is 12volts...
    *jjservice*
    if you think i helped youkindly press REP+THANKS button
  7. #6531
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    The plug 51 and plug 48 has a different color if your digiprog is clone.... if the digiprog is clone the wires colors is not same from the original plug 51 has ORANGE/BLACK/BROWN/RED and the plug 48 as well same color but not the same pin out of the 2 wires.... only the 12v and 5v.
    Hi all.
    I need help with Volvo v70 2005, i have solderd and colour code converted adapter 51 and also tried with 48, i get "INIT ERROR", i have check and re-checked connections but cant find anything.
    Do i need to connect the dash to car and then do Digiprog?
    Do i need to program the digiprog unit by PC or so before using it?
    I have also tried HC12 and HCS12 both give same "INIT ERROR"
    *jjservice*
  8. The Following User Says Thank You to jjservice For This Useful Post:
    Alexxelax (26th September, 2018)
  9. #6532
    Sep 2018
    Quote Originally Posted by jjservice View Post
    Thanks for answer
    Yes i have a clone.
    I found the colour codes, and after searching online i found some other guides that tell the colour codes original vs clone.
    I used 51 as manual said but when not working i tried with 48 but still nothing, the cluster clock just come on very little. After all i installed in car and it did not work anymore, so i started to check soldering but nothing.
    The biggest question is have the digiprog fried the cluster? If yes, why did that happen, was it my fault or is the digiprog not compatible with volvo clusters? And is soldering wrong cables so dangerous to damage cluster?
  10. #6533
    Sep 2018
    *jjservice*
    My manual say use 51 on volvo v70, and the volvo s80 uses 48
    My car is 2005 v70
  11. #6534
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    My car is 2005 v70
    Well maybe you had a wrong connection s0ldered wires.
    *jjservice*
  12. #6535
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    can digiprog read and write this 93c86 eeprom form 2017 ford everest / ranger see image seems like latest sc667351 version
    this is dash with 2 x lcd screens on both sides of the speedometer in middle
    tried and only got chip error - luckily no data erase soldered chip back old mileage intact - what tool recommended to read write this 93c86 chip
    'If I helped, please click Thanks +Reputation.. !'
  13. #6536
    Mar 2013
    Europe
    You can use Digiprog every time as EEPROM Programmer
    You can load after read to PC and edit and send edit EEPROM file back to Digiprog and write with EEPROM clip back.
    For good read EEPROM, every time desolder and read.
    Dont read in curcuit EEPROM ;-)
  14. The Following 2 Users Say Thank You to bersch8688 For This Useful Post:
    brend (6th October, 2018), rtbdiagnostic (1st October, 2018)
  15. #6537
    brend's Avatar
    Oct 2015
    Same where
    Absolutely right!!!
    Quote Originally Posted by bersch8688 View Post
  16. The Following User Says Thank You to brend For This Useful Post:
    bersch8688 (8th October, 2018)
  17. #6538
    May 2015
    My Tool Room
    Quote Originally Posted by Speedofix View Post
    amarok not working 4.94 and 4.88
    i also tried a 2015 Amarok no success
  18. #6539
    letalcrudo's Avatar
    Nov 2015
    Canada
    I've tried on Amarok from 2011-2015... I had success on 8/10 ... V4.88
  19. The Following User Says Thank You to letalcrudo For This Useful Post:
    rtbdiagnostic (8th October, 2018)
  20. #6540
    Jun 2013
    Hallo my digi no Read 95160. Any Solutions?
    Wysłane z mojego SM-G390F przy użyciu Tapatalka
