Page 102 of 462 FirstFirst ... 25292979899100101102103104105106107112152202 ... LastLast
Results 1,516 to 1,530 of 6917
  1. #1516
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by cheester View Post
    Have you fix your cas plug in some way?
    Whre did you buy it?
    He says he did it by obd not cas plug
  2. #1517
    ovi_dk's Avatar
    On board
    Nissan Navara 2009 with 9S12 i do today and all work perfect aslo one audi A3 2006 diag like a charm
    If u have the answer say Thank You!!
  3. #1518
    andkl2810's Avatar
    Aug 2012
    SLAVA UKRAINI !!! GEROJAM SLAVA !!!!
    WV T5 (Facelift) 2011 Dash UDS 2 min perfect
  4. #1519
    I have had error no connection replaced 9 pin socket on digi problem solved
  5. The Following User Says Thank You to diagtech For This Useful Post:
    Automat (27th March, 2016)
  6. #1520
    workshop
    on digiprog?you mean com port?
  7. #1521
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by mercis View Post
    No he means 9 pin connector on obd cable
  8. #1522
    workshop
    my digi dont work with obd cable,will change
    thx
  9. #1523
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    thx
    Search this thread I have posted pictures with pin numbers
  10. The Following User Says Thank You to teerak2uk For This Useful Post:
    mercis (22nd April, 2013)
  11. #1524
    justy22's Avatar
    May 2009
    UK
    Cable 48/2 warning I found my one was wired wrong way at 25 pin plug white and brown around the wrong way, open up 25 pin and check it my one even had a quality control sticker on it Also 2007 Ford connect OK via cable 48
  12. The Following 2 Users Say Thank You to justy22 For This Useful Post:
    kronk92 (26th February, 2017), PremierD (22nd April, 2013)
  13. #1525
    I think now we can safely say this is good only on German marques and some Opel.
    If its french, forget it.
    If you wish to use for reading and writing by clip, forget it.
    Peugeot 206 2006 BSI Auto Not working Dash Not Working
    95020 by clip, Read incorrect, Verify Not working, Write Not Working
    35080 by clip, Read Incorrect, Erase Not Working, Write.....take a guess.
    Ive now plugged to most Peugeots and its a hopeless case. Ours is Ebay bound. My advice is use your money towards an AVDI which Kap currently have on offer (is a hardware change imminent or are the chinese getting too close) or one of SMOKS tools and do a brand correctly. This heap will only ever cost you time and heartache.
  14. #1526
    batandball's Avatar
    May 2011
    Are you joking. I paid more for my last update for one of my machines ???
    theres something wrong with your machine or user error
    If it works use it
    BatandBall
  15. #1527
    We bought from ADK. Blue PCB and quality looks pertty fair for china crap. Even tagging of the OBD cable looks good. Changed the DB9 we gained nothing from it. Luckily we have a good kit for mainstream work but this would have been a nice consolidated cheap device for the bench if it would read by clip. Just tried reading 95128 known good and it failed again.
    Read incorrect mileage on DISCO 3 last week thats how bad this is. May try reflashing before ebay.
  16. #1528
    Quote Originally Posted by batandball View Post
    Reading this thread.......which french cars have you plugged to?????
  17. #1529
    batandball's Avatar
    May 2011
    some chips dont read when you go into utilties but they read in vehicle program then if you go to utilities chip number it will have the data there
    If it works use it
    BatandBall
  18. #1530
    wadim21's Avatar
    Sep 2011
    crysler caravan 2005 not working
  19. The Following User Says Thank You to wadim21 For This Useful Post:
    shirokov (13th May, 2013)
