how u know if its yanhua?:P
I've read loads of chips with mine. Doesn't like some chips on board, 95020's being one of them. If your having that much trouble, send it back. I returned one of mine and it has saved me a lot of aggro and a lot of money. It seems their is a few dodgy ones around but the ones that work are pretty good. I would recommend paying a little bit extra and getting the Yanhua machine that is made better.
If freedom is outlawed, only outlaws will have freedom!!!!
Most sites are selling a cheaper one and the Yanhua one but the Yanhua is a bit more expensive. True, there is nothing to say they are not made at the Yanhua factory but some sites I've seen are guaranteeing that there won't be any problems with the Yanhua. IE: white screen etc.
It sounds like you've got a bad one. After reading your post I went out today and did a 2010 Citroen Berlingo dash and BSI with my CLONE DIGIPROG 3 and the job was perfect. I did a BMW 3 series CAS3+ via OBD and dash 35080. Used a 35080 that I had previously zeroed at home though. It is obvious that some of these machines are poorly made. I have one that only does OBD stuff so there is obviously something wrong with it but I paid ?160 for it and for that money I can't complain. My second machine (from a different supplier) has done everything I've thrown at it thus far. If your machine is playing up just send it back. It cost me ?16 to get a tracking number and it came back a month later, fully functioning.
I'm not taking my unit apart. They all look the same from the outside and I'm not breaking the warranty seal. Just Google.
Vivaro 2005 95020 ok with ST01/04 use unit in km to see correct values
Does anyone know if Digiprog 3 of ecutool is of good quality?
This is the link:
Hotest Digiprog III Digiprog 3 Odometer Programmer with Full Software New Release
Vw touran 2006 dash and ecu work OK
Just made new cable today for clip. Tested and 100% perfect and also made adapter to enable swapping to xprog and upa. Everything reads fine via cable apart from digibodge. Looks like we got a lemon but tempted to reflash the unit. Getting some strange results with this kit and different results even with sequential re-reads. Read 95020 and from 0x80 onwards we get FF's. Also noticed that the read is one line short on data too. From car/truck menu all reads state 0KM.
But reading from the Car/truck menu we are getting incorrect reads. Just dug out a vivaro dump and written to chip with xprog. Read mileage with digiprog and its incorrect. Write a new mileage and it is then read again and its showing 0KM. Check again with xprog and upa and sure enough 0xF is full of 00's. We have problems on both eeprom and OBD side so Im assuming hardware is fine through both sockets although now both are changed. I think the flash is dud or theres a board or component issue. Will have a look further into when time is more plentiful.
berlingo 08mod, read write dash, bsi uknow version done with nyo.
Reworked all joints on our board last last night. Reading eeproms very well so far and reads on the board too with a fair few tested. Now getting excellent reads with all addresses showing correct data. Now working with Pug BSI units too. Still need to test OBD but confident.
Think mine has problems reading eeproms, i've checked my cables and they are fine, might have to do a rework too
2008 Suzuki Swift, strip dash and clip 93c66, got no connection, took eeprom out and read in my labtool again, modified using Tachosoft etc..
connected to a mates 2010 Audi A5 2.0TFSI petrol and it read mileage from dash correctly, i didn't IN-correct it though, just tried a read.
do i need to do ECU too in this petrol car? how do i check the ecu?
cheers
