Does anyone know what lead ST79 is used for?
hello
Does anyone know what lead ST62 for cas diag bmw ?
Lead ST62 is supposed to conect to the dash plug going to the cluster on E60 E90 E65 to programme the CAS. E65 uses a different connector than the others. I would however not attempt to use clone to do this as the E65 CAS can be damaged if the wrong socket is used. I dont know which socket is which.
Lead ST62 is NOT provide with Digiprog. I think this option will not work !
Carradio2001.
This is the one that came with mine
If it works use it
BatandBall
In short I have yet to successfully do a CAS unit with the clone. I have also tried the HC12 cable, which I got from repsoft which also doesn't work with the clone.
If things seem under control, you are just not going fast enough!!
Tried to do EZS unit on Merc Vito with no success had to use original DigiProg
hello
is there anyone who knows how to use the cable 49 for the W203 ?
