Page 417 of 462 FirstFirst ... 317367407412413414415416417418419420421422427 ... LastLast
Results 6,241 to 6,255 of 6920
  1. #6241
    autocargo's Avatar
    My old Digiprog broke so I bought another from China... New one doesn't work on focus 1 with motorolla hc11 (adapter no.27)... Anybody have a solution to this? Thanks.
  2. #6242
    Dec 2016
    Poland
    Quote Originally Posted by autocargo View Post
    hhave You checked the adapter with multimeter? no shortage?
  3. #6243
    autocargo's Avatar
    I'ts all good... but my new digiprog doesn't put hc11 in boot mode.... maybe someone had same problem and found a solution...
  4. #6244
    Jan 2017
    Poland
    anyone tested Renault Master '2007 with 93C66 ?
    need to desolder or can I try with ST01?
  5. #6245
    skens's Avatar
    Mar 2010
    Zagreb,Croatia
    hi
    honda CRV Fourth generation (2012–2016) RM1, RM3, RM4) c76x16
    Digiprog clone read and write use meni CR-Z
    regards
    Please dear members push the button thanks and reputation button(stars)
    do you need help? fill it in !!!
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    ECU type and number:
    Memories :
    https://www.digital-kaos.co.uk/forum...63#post1660863
  6. #6246
    skens's Avatar
    Mar 2010
    Zagreb,Croatia
    hi
    desolder
    regards
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    Memories :
  7. #6247
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by skens View Post
    hi
    desolder
    regards
    no desolder
  8. #6248
    Jan 2017
    Poland
    Nicolas9, Skens
    so can i do it by ST01 on PCB without soldering?
    Wysłane z mojego K920 (CN) przy użyciu Tapatalka
  9. #6249
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by remont View Post
    Nicolas9, Skens
    Risky .
  10. #6250
    Dec 2009
    Serbia
    Audi A6 4F Facelift 2011 Color display done 20min
  11. #6251
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Quote Originally Posted by teerak2uk View Post
    Risky .
    I see that with Enigma can go direct with cable C4 to chip 93c66 - I prefer desoldering then read and write saves you a lot of stress ...
    'If I helped, please click Thanks +Reputation.. !'
  12. #6252
    mikhailzgv's Avatar
    Aug 2012
    Furstenberg/Havel
    touareg 7p machen km chenge ?
  13. #6253
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Not by obd. First reset eeprom. Then do by obd.
    (Nicht uber obd. Zu erst eeprom programmieren. Danach kannst du durch obd auf correcte stand programmieren)
  14. #6254
    Mar 2013
    Europe
    Digi dont do it VW Touareg 7P!
    After prepare eeprom in Dash you have DEF
  15. The Following User Says Thank You to bersch8688 For This Useful Post:
    mikhailzgv (6th November, 2017)
  16. #6255
    Oct 2017
    Default fiat bravo digiprog 4.94
    hola consulto mi digi no baja los kilometros a fiat siena 2013 con 95160 pero si los sube podria yo subirlo a999999 luego hacerlo andar unos kilometros y subirlo a lo que necesito quisiera saber si alguien lo hizo para no provar sin saber muchas gracias
