My old Digiprog broke so I bought another from China... New one doesn't work on focus 1 with motorolla hc11 (adapter no.27)... Anybody have a solution to this? Thanks.
I'ts all good... but my new digiprog doesn't put hc11 in boot mode.... maybe someone had same problem and found a solution...
anyone tested Renault Master '2007 with 93C66 ?
need to desolder or can I try with ST01?
hi
honda CRV Fourth generation (2012–2016) RM1, RM3, RM4) c76x16
Digiprog clone read and write use meni CR-Z
regards
Please dear members push the button thanks and reputation button(stars)
do you need help? fill it in !!!
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
ECU type and number:
Memories :
https://www.digital-kaos.co.uk/forum...63#post1660863
hi
desolder
regards
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
Memories :
Nicolas9, Skens
so can i do it by ST01 on PCB without soldering?
Wysłane z mojego K920 (CN) przy użyciu Tapatalka
Audi A6 4F Facelift 2011 Color display done 20min
touareg 7p machen km chenge ?
Not by obd. First reset eeprom. Then do by obd.
(Nicht uber obd. Zu erst eeprom programmieren. Danach kannst du durch obd auf correcte stand programmieren)
Digi dont do it VW Touareg 7P!
After prepare eeprom in Dash you have DEF
mikhailzgv (6th November, 2017)
hola consulto mi digi no baja los kilometros a fiat siena 2013 con 95160 pero si los sube podria yo subirlo a999999 luego hacerlo andar unos kilometros y subirlo a lo que necesito quisiera saber si alguien lo hizo para no provar sin saber muchas gracias
