Hi!
Digiprog clon Win 7
Hello
Can I read eeprom 95320 (gateway of Audi A6 C6) by Digiprog 4.94 clone by clips SOIC8?
and save to *.bin file ?
is it safe or not?
Yes you can!!!!
If i help, d'not forget to press thank button!!
remont (20th June, 2017)
Antenor, did you test it? Dump is ok?
Wysłane z mojego K920 (CN) przy użyciu Tapatalka
nissan nv200
yellow - bdm
brown - gnd
green - reset
white - 5V
use qashqai HCS12 works 100% see attached pics for pinout from backside of cluster no needle removal quick job
'If I helped, please click Thanks +Reputation.. !'
Hello friends. Whether prompt who tried to correct opel astra g 2011? Is the probability of a damaged panel? There is digiprog3 with version 4.94M.
charlesauto07 (23rd June, 2017)
SANCHELO (23rd June, 2017)
Astra g is 35080 in cluster you need to use blank eeprom
memet99600 (27th June, 2017), rtbdiagnostic (24th June, 2017), SANCHELO (24th June, 2017)
Sorry your right 2011 could be astra h or j
Hello friends I need to change the mileage of a mercedes clc 2009 which tool can do well for obd? Digiprog error with w204 diag should i choose another model? Or is it not possible? Thank you
