Digiprog 3 clone questions and answers - Page 416
Page 416 of 462 FirstFirst ... 316366406411412413414415416417418419420421426 ... LastLast
Results 6,226 to 6,240 of 6917
  1. #6226
    Nicolas9's Avatar
    Feb 2017
    Aruba
    no you cant.
    use search to find out how to change (you dont use digiprog)
  2. #6227
    Jul 2012
    Anyone would recommend me a good seller from ALI ? I'd like to buy tool with FTDI chip, not necessarly with all adapters - just OBD and EEPROM.
  3. #6228
    Feb 2017
    UK
    hi all
    I have question about digiprog 3
    Touchscreen does not work I bought new screen but also does not work
  4. #6229
    Dec 2009
    Default DIGIPROG IC U31
    Please need help
    did someone can see what component is u31?
    thanx
  5. #6230
    Aug 2016
    Hi!
    Does DP3 from China 4.94 with FTDI is able to change mileage on Passat B6 24C32/ 24C64 NEC chip thru OBDII?
    I'd buy from aliexpress.
  6. #6231
    May 2010
    Quote Originally Posted by passatv6 View Post
    Hi!
    try it and find out
  7. #6232
    Feb 2017
    Madrid Spain
    Hello friends someone tried digiprog 4.94 to make Mercedes SLK 200 2005 ??? Do you block ezs to 1.666666 or correct the value?
  8. #6233
    Dec 2009
    Quote Originally Posted by carbyvw View Post
    Please need help
    thanx
    nobody can help me?
  9. #6234
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    W171 SLK dash via ST60 then have to do EZS with R270 or red rosfar Micro HC9s12 also do the ZGW gateway module then you have a proper job done ...
    'If I helped, please click Thanks +Reputation.. !'
  10. #6235
    May 2015
    My Tool Room
    Default 2011 ford bantam
    any advice on whats inside could it be 24c08 for this year model - any pinouts to share or the safe old way eeprom off read and write
  11. #6236
    Sep 2015
    hi guys...I see on web someone is using hc12 and nec adapter on clone dp3..I try original hc12 adapter on it and dont work..anyone now what need to be modyfied to make it work?thanks
  12. #6237
    Apr 2012
    US
    Hi mates,
    i just did a 2010 Volvo XC60 everything seemed good, but when I check with Delphi, 2 permanent faults
    C2000262 odometer changed & U300045 ECU internal fault, the car runs good, no message on the display, how can I solve this?
    thanks in advance
    regards
  13. #6238
    sida's Avatar
    May 2014
    System32
    Quote Originally Posted by danielboom00 View Post
    Hi mates,
    thanks in advance
    regards
    Do CEM also..
  14. The Following User Says Thank You to sida For This Useful Post:
    danielboom00 (18th September, 2017)
  15. #6239
    Nicolas9's Avatar
    Feb 2017
    Aruba
    2010 cem will take mileage (at least at mine car).
    Erase faults and see if comes back.
  16. The Following User Says Thank You to Nicolas9 For This Useful Post:
  17. #6240
    Mar 2017
    Please need help
    thanx
    On mine theres an AU5790D on that position, but it's marked U17B, so I dont know if pcbs are different.
