Page 437 of 462 FirstFirst ... 337387427432433434435436437438439440441442447 ... LastLast
Results 6,541 to 6,555 of 6917
  1. #6541
    letalcrudo's Avatar
    Nov 2015
    Canada
    Quote Originally Posted by wbart View Post
    Hallo my digi no Read 95160. Any Solutions?
    Wysłane z mojego SM-G390F przy użyciu Tapatalka
    do you read on circuit or desolder the eeprom and put in adapter?
  2. #6542
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Desolder and clean chip.
  3. #6543
    Dec 2010
    vietnam
    hi! Anyone have a repair solution to be able to read Motorola 05H12? thankyou very murch!
  4. #6544
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Quote Originally Posted by letalcrudo View Post
    I've tried on Amarok from 2011-2015... I had success on 8/10 ... V4.88
    Attachment 562461
    I eventually used x300m to fix the 2015 vw amarok dash quick job
    'If I helped, please click Thanks +Reputation.. !'
  5. The Following User Says Thank You to rtbdiagnostic For This Useful Post:
    letalcrudo (11th October, 2018)
  6. #6545
    letalcrudo's Avatar
    Nov 2015
    Canada
    Quote Originally Posted by rtbdiagnostic View Post
    I'm making up my mind about buying that tool or smok...
  7. #6546
    May 2018
    Hello everyone,
    I need help for toyota prius mk2, i've just open a new thread for that here: http://www.digital-kaos.co.uk/forums...ection-(93CS66)
    So if somebody know how to do that it would be wonderful !
    thanks in advance
  8. #6547
    Apr 2017
    Christchurch, NZ
    Citroen C5 2003 Sagem BSI- changing mileage, ok. I tried the dashboard (HC08) with plug 42, no luck. I checked the pinout first and that seems correct. I had four connection attempt and failed all the time. I'm going to get Carprog to do the dashboard. Anyone has success with CP (clone obviously) on this? Thanks
    Last edited by nagy592; 15th October, 2018 at 09:29 PM. Reason: Missing information
  9. #6548
    Feb 2010
    Hi, somebody successfully did a 2015 fiat scudo (same as Peugeot expert/ Citroen jumpy dispatch/ Toyota proace)? Customer installed and used JC bsi and now car has more mileage and need to downgrade it. Never used this tool, and a friend let me his tool to make the job.
    Enviado desde mi SM-G960F mediante Tapatalk
  10. #6549
    Jun 2011
    Northamptonshire, UK
    Quote Originally Posted by hipolitogt View Post
    These are ok with digi..
    95128 in the bsi.. it is covered in lacquer.. so need to remove that first.. can be done on the board but safer to remove.. you need to do dashboard also which is a 25020 I think... but again digi can do no problem..
    Sent from my SM-G935F using Tapatalk
  11. #6550
    Feb 2010
    Quote Originally Posted by Music73 View Post
    Thank you!!!
  12. #6551
    Jun 2013
    Poland
    Eeprom desolder and read only ff
  13. #6552
    honingkoning's Avatar
    Jun 2010
    Dessert
    Jeep grand Cherokee 96 with digi (4.85) ok.
  14. #6553
    Jun 2013
    Poland
    Hallo mates
    My digi work kline and can ok but eeprom Read bad. What with it ? Any Solutions?
  15. #6554
    Jun 2013
    Poland
    Quote Originally Posted by davecooper47 View Post
    I have 2 digiprogs. Both work ok for OBD but one of them will not read all eeproms. One of them is fine but the other will only read 95xxx eeproms and not 93cxx or 24cxxx. I suspect there is something wrong with the buffer chips (hc125's etc). The problem is that all of the chips have had the tops ground off so I don't know which chips to change. Can someone help me with this please.
    Hallo .
    Ihave the same problem. Resolve you problem? Mayby anyone have solutions?
  16. #6555
    davecooper47's Avatar
    Dec 2010
    Yes. I just bought a new one. They’re so cheap now.
