renault laguna 1.9 dCI, 88 kw, chiptuning project
Results 1 to 7 of 7
    Newbie gost's Avatar
    Feb 2011
    Romania
    Lightbulb renault laguna 1.9 dCI, 88 kw, chiptuning project
    Good afternoon all ! I own a renault laguna 2, 1.9 dCI, 88Kw car and i'm in love with it... So basically i'd like to keep it as long as i can but i want to improve it a little so i was thinking to try a remap... The main problem is that my knowledge in chip tuning is not very well so i'd like other participants to give advices or to correct me if i will post something wrong So i will download the .ori fille and i will post it here... step by step i will try to identify the maps and to modify them... good luck !
    Jul 2012
    I think it's a good idea .. I'm sure someone will give you a hand for your work ... otherwise you can ask for a good job if you want to pay and save time and after studies to make improvements
    Feb 2011
    Romania
    Default original DUMP from the ECM
    this is the file downloaded from my car's ECM. From now on i will try to modify it and i will post here the results. Please inform me if i will do something wrong....this is my first kind of project and there is a big possibility to mess everything
    Feb 2011
    Romania
    Default first task: EGR OFF
    First thing that i did was an easy one: I have disabled the EGR functionality after what i've seen on the engine's air intake... Correct me if i'm wrong but the EGR map is on the adress 6CF14, 15x15. I have linearized all the values to 11100 (EGR closed). Now i will try to identify other maps...
    Jul 2012
    Quote Originally Posted by gost View Post
    egr off you if you bring value to the maximum .. you have an error in diagnosis, but it does not matter
    Feb 2011
    Romania
    not true....i did a diagnostic scan after uploading the file with the EGR off and no erorr was reported
    Feb 2011
    Romania
    Project reloaded ! I upgraded some hardware - bigger intercooler, decat, stright pipe 60mm exhaust, new turbo - GT2052V and added a new software...but something is wrong......very wrong.I have installed a boost gauge with the range from 0 to 2bar. The problem is that when i press the accelerator pedal to the maximum, the boost value goes to the maximum of the gauge ... over 2 bar !!! With the stock .bin the turbo boost is limited at 1.2bar. Now i want to install a BOSCH 0281002845 3bar MAP sensor but i couldn't find the MAP linearisation map... A little help please
