Results 1 to 14 of 14
Thread: TS Panel
    Jul 2012
    Default TS Panel
    can anyone tell me where I can download TSpanel
    digicon's Avatar
    Quote Originally Posted by Dave01iver View Post
    A fellow member had kindly posted it a while back, A search would have brought this up
    Thanks to the poster
    http://www.digital-kaos.co.uk/forums...9/#post1572176
    Also here right under your post
    http://www.digital-kaos.co.uk/forums...owners-208855/
    And here
    http://www.digital-kaos.co.uk/forums...-image-205464/
    Sep 2012
    Installed TSPanel but not showing in plugins, running black hole. Anyone know where it can be found.
    BANJA LUKA,BIH
    JUST PUSH THE MENU BUTTON...
    V.I.P. Member benny/9's Avatar
    Nov 2008
    north west uk
    Quote Originally Posted by fjle View Post
    i have read that the latest versions of the tspanel
    dont load on some of the latest vu images, and it
    was stated to load a earlier tspanel version like the
    v4.9 and once loaded you can update the tspanel to
    the latest version, or better still just load the cams
    via the tmp folder, you will find them here in post 2
    of this thread,
    http://www.digital-kaos.co.uk/forums...-cccam-287037/
    Please Read Carefully!
    No Sky UK NDS Videoguard Hacking Discussions.
    Viewing Pay TV without a valid subscription is illegal
    the files available are kept for experimental & educational purpose only
    original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,
    May 2011
    I just got the same trouble
    Updated my image from a perfectly working blackhole (why must I always try and "improve" things!)
    now running DE4.0 but no TSpanel. I manually installed the ipk but it's not showing anywhere even after a reboot.
    help ?
    Jan 2013
    where can i finde ts panel for vu+solo2 rining blackhole 1.7.9-3 ?
    thanks in advance
    Mar 2011
    Digital Kaos - Downloads - blackhole ts panel
    blackhole ts panel
    click link above
    May 2012
    Under the cosh
    Quick Question about TS-PAnel and what its doing behind the scenes.
    IIRC the VIX team removed the TSPanel plugin from the VIX feeds - their reason was that it was hacking about behind the scenes with some of the image or config files.
    This is the reason I haven't loaded it since.
    Any comments on this? I'd like to re-install, but won't if the VIX devs are right.
    Nov 2008
    north west uk
    Quote Originally Posted by meggiedude View Post
    why not just load the cams
  11. The Following 2 Users Say Thank You to benny/9 For This Useful Post:
    dbj159 (4th April, 2013), oldeno (25th March, 2013)
  12. #11
    Sep 2010
    The reason why it was removed from the ViX feeds is because during it's install process it overwrites many image critical system files. This both causes instabilities within the image ( one of which affects PTS ) and it makes a full install almost impossible.
    Pli have also stated the same on their own forum with reference to the TSpanel
    as for cams you can download them directly from the same place as the ViX images as there now hosted on our own download server.
  13. #12
    Jan 2009
    I am looking for tspanel download open for pli4 to upload by usb to my vu+duo2 many thanks in advance
  14. #13
    Nov 2008
    north west uk
    Quote Originally Posted by turket View Post
    first thing you dont load the tspanel with a usb stick
    it has to be loaded with a DCC , if you want to use this
    for the extra items for the image we do help with on the forum the image has everything built in it, if you press menu on the box and go to pluggins>ok when the pluggin list appears press green and the image server will upload anouther list of pluggins where all you need is there
  15. #14
    Nov 2014
    i nead tspanel dowlode thu vu+solo2 tgz fil ?
