Results 1 to 8 of 8
    Jul 2012
    Shenzhen
    Thumbs up Buy DIGIMASTER III ORIGINAL ODOMETER tool win digipro3 free
    Digimaster3 Mileage Correction Tool only 799USD
    DigiMaster-III is the third generation multi-functional Automobile data adjusting equipment.
    It bases on a high performance hardware platform which takes high-speed CPLD and the ARM11 processor as the core device. Seven inch LCD touch-screen with high resolution makes its interface easy-used.
    Working with various types of adapter you can easily achieve odometer correction Audio decoding airbag resetting engine ECU resetting IMMO, programming key for Benz and BMW etc.
    It is applicative for all types of data processing such as OBD connection, dashboard soldering, CAS-BDM. It contains the advanced technology of programming new keys for BMW and Benz, CAS-BDM reading/writing and resetting, 35080V6 erasure etc.
    The operation interface is highly user friendly, large numbers of pictures and particular description makes your operation pleasant. Online updating and module authorization keeps you always on the leading edge of technology.
    Digimaster III
    OBD Socket
    Volkswagen/Audi/Mercedes-Benz/BMW adjust form Diagnostic socket
    NEC Adapter
    Applicable to CPU free switch connecting of NEC series.
    35080 V6 Adapter
    For 35080 series IC erasing and writing
    CAN OBD DMI
    Applicable to process of some Audi A6L & A8L.and VW
    LS400 Adapter
    Applicable to odometer IC(457C) of LexusLS400(1992-1994)
    W211 Adapter
    Applicable to process of EIS ECU module for Benz E Class W221(2002-2005)
    BMW-CAN Adapter
    Applicable to process of CAS ECU module (odometer socket)for BMW 3/5/7 series E90/E60/E66(after 2005)
    CAS-BDM programmer
    Applicable to process CAS1\CAS2\CAS3\CAS4 ECU module (DG128/256/512)for
    BMW 3/5/7 series
    AZ60_F Adapter
    Quickly read and write EIS ECU of Benz
    ESLconnector
    1.MOTOROLA key chio;
    2.E Class W210 ESL(05E6/G72A);
    3.E Class W211 ESL(05E6/0F82B);
    4.CLK Class W208 ESL(05E6/G72A);
    5.CLK Class W209 ESL(05E6/0F82B);
    6.CLS Class W219 ESL(05E6/0F82B);
    7.C Class W202 ESL(05E6/G72A);
    8.C Class W203 ESL(05E6/0F82B);
    29F Adapter
    Old Mercedes Benz DME 29F400 and 29F800 Chip
    Meter Socket
    Adjust Benz\ BMW\Jaguar\Ford meter from meter socket
    TMS370Programmer
    Applicable to anti-theft reading for old Jetta, audio decoding for Deco and Opel.
    K&CAN Adapter
    1Applicable to airbag resetting via K-Cable
    2 CAS module programming for BMW.
    9S12 Adapter
    Applicable to CAS ECU module programming for BMW 3/5/7 series of electronic
    chassis E90/E60/E66 (after 2005), and EIS ECU module programming for
    Mercedes-Benz S/E/C class of electronic chassis W220/W211/W203(after 2005)
    Grand Cherokee Adapter
    Applicable to odometer CPU of Grand Cherokee
    E65/E66 Adapter
    Applicable to process of CAS ECU module for BMW 7 series E65/E66(2002-2004)
    W220/W203 Adapter
    Applicable to EIS ECU module programming of Mercedes-Benz C/S class
    electronic chassis W220/W203/W215/R230
    MC711 Adapter
    Old BMW EWS2(2D47J,0D46J) / EWS3 2D47J,0D46J)
    MC705 Adapter
    1.S Class W140 DAS IMMO ECU 05X32(0D69J)
    2.S Class W140 DAS IMMO ECU 05X32(0D53J/0D62J)
    3.S Class W220 EIS ignition module 05X32(1D69J)
    4.CLK Class W208 EIS ignition module 05X32(1D69J)
    5.C Class W202 EIS ignition module 05X32(1D69J)
    6.E Class W210 EIS ignition module 05X32(1D69J)
    7.ML Class W163 AAM 05X32(G47V/1D69J )
    EWS-K Adapter
    adjust EWS through K line
    MC705E6 Adapter
    MOTOROLA key chip
    IAR Adapter
    Write Benz key
    NXP Adapter
    BMW key chip and key
    7936 7941 7942 7943 7944 7945 7946 7947 7952 7961
    NEC KEY Adapter
    Mercedes Benz S, C, E, SL, CL, CLK and CLS Class Key
    OBP Adapter
    Applicable to EEPROM meter, airbag ECU, audio ECU which need to be
    unsoldered.
    ICP Adapter
    Applicable to free stitches of 93 series, 25 series, 35080 EEPROM, CPU meter,
    airbag ECU, audio, ECU, etc.
    DK Veteran wsc's Avatar
    Aug 2009
    GR
    The shitest tool I have ever bought ... completely useless
    Smart car engineer ,
    Mar 2011
    Default so cheap?
    Is it so cheap? I have never know Digimaster 3 is so cheap. As I know, it is 2000USD...
    Dunker's Avatar
    Yorkshire
    This dick head is spamming loads of forums.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
    Jul 2010
    Yes Original Digimaster III cost a bit on 2000USD
    Nov 2009
    Not bad price
    Dec 2009
    where can i find this tool for that price ? and is this a good tool or a fake one as the other china tools ?
    Dec 2012
    Digimaster 3 costs about $2000, not $700!
