Carprog reprogramming - final solution - Page 10
Page 10 of 10 FirstFirst ... 5678910
Results 136 to 140 of 140
  1. #136
    Newbie 1000tc's Avatar
    Hi all, I do not know if they are in the post right to ask information about a Carprog.
    I own Carprog V5.46 clone complete with 21 adapters purchased almost two years, I have never used and never installed the program, I wanted to ask if I can install the latest version of V 7.28 Carprog if it works or I have to make changes.
    Thank you for your answers
  2. #137
    Jun 2011
    Northamptonshire, UK
    Will work but there are no more activations than older software...
  3. #138
    7936
    Guest
    Elchip is right the 88 dump should not be public. A lot should not of been. been out the game little while if some one can get ahold of ray-ray i need location of immo location code in us fiat. If you wanted the dump of the 88 just get a data logger (pirate bus less the 33 usd) program a few chip with different passes log. Comp differences. Or get ida out dis asm. The code and scematics the asians started with were stolen from the company and sold. the 88 is only the only thing keeping cloned asians updated rest is there if you bought a new unit and had some skills. The 33 sbb was able to be fixed but just releasing a write protect let them sell v33 and make pockets fatter. The sdd older clones where better. If the asians clone something or soft is being sold cracked it ok to release. Keygens should not be publics for first year or two on certain soft. If you make a keygen you should share keys. I use to in the us get minimum 200 a job dash immo key us, I gave up for a while people stopped wanting to pay for stuff because mr im ok with working out back of car for pennies. Code was posted for edc17 immo off then every one and there brother broke out vb and tried to make money. Half do not even change right line of code.
  4. The Following User Says Thank You to 7936 For This Useful Post:
    Youneselm (28th December, 2015)
  5. #139
    Mar 2015
    Hi friends , elchip or 7936 can you help me , my problem is my AT88 was erased can you say me where i can find one programmed thanks by advance
  6. #140
    May 2016
    romania
    mate the counter will apear again after couple utilisation !!! every time apears the counter i reflash the arm!!!
