Results 1 to 8 of 8
    Default Twingo 6R.30 immo
    I have an old ecu from twingo model 1996 MM 6R30 . I always unlocked these ecus with renault decoder . This ecu doesn t unlock so i want to ask if someone has read tms370 with x-prog v5.0 clone or upa v1.2 clone and also if someone has tested file from tms 370 for im#o off .
    regards
    Problem solved .
    regards
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by antlio View Post
    Problem solved .
    regards
    Explain what you did, in future people dont have to bother you by pm and it saves new topics with same question.
    Regards Adam
    I used 11 volt in decoder .
    Meat-Head's Avatar
    can you explain a little for for thick people plase?
    luis12's Avatar
    Jan 2011
    Panama
    Very usefull tip, please explain more detailed, thanks.
    I conexted ecu with decoder i used 11 volt to decoder and i started the procedure . When the mil stoped to flash i cut pin 25 and the ecu was no im%o .
    regards
  8. The Following User Says Thank You to antlio For This Useful Post:
    didi_du_93000 (19th October, 2013)
    didi_du_93000's Avatar
    France Paris
    Minr don't work. i have tested standar advanced 1 and advanced 2.
    Always light blinking.
