This car has central locking.
Customer has one remote key at present but requires a spare.
peugeot + toyota, next cooperation citroen crosser + mitsubishi, remote besides authorized serivis, any ideas?
fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
Why do you say a used item can’t be adapted?
This key has a separate 4D chip.
old megan scenic also has 4d, I have not seen someone coded it again, I can be wrong, I can not see the clones of these keys.. "remote synchro +4d... id 60..1,2,3,4,5,6
I tried that process but only worked for original.
I have now left the job.
what you mean process worked for original? for completely new remote from dealer or new made by KEYDIY?
I wonder if keydiy works 100%.
You CAN reprogram used remotes without a problem.
And KD does a good job on it. Had a C1 today. First tryd on a NB multifunctional remote with KeyDiy X2 (new function), but the car rejected the remote (did detect it, but opens/closes 2x after pushing the button).
You're talking about completely different things here. PSA remotes has nothing to do with Toyota Aygo/C1/Pug107. They use different algo and even PCB of both types looks the same - they are NOT. Firmware in MCU has nothing common in between. PSA are pain in the @ss but Aygo's can be reused more easily.
hi,i was talking about bero post from above who was saying you can reprogram used remote,as far as i know to take a used remote and simply program it to another car (107-c1-aygo) just that is not possible,,it must be renew first if i am not wrong off course,so if it another option can you share the way?
