firstly which box are you using? the tntsat channels open on most boxs patched with 3rd party firmware or via gbox/oscamymod on E2 boxs. start a new thread in your relevent box section or general sat section describing your box,dish size and location and someone will be able to help/advise you. regards mdt
DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W
Many thanks for your answer, before opening a new thread, i give you the response to your question my box is t: Tm9600Hd Combo super +,Phantom patch 752, pluss the up to date keys.I have try connect on the frequency for TNT SAT and the box doesn't decode the channels, as it is wrote that the keys opens the TNT SAT i thing i must use some other way to decode these channels.Regards
22-5-2013
B***** NOW AND NEXT
THANKS TO TECHNOMAKER
regards mdt
Hello mdt many thanks for your reply , but was "B*****NOW AND NEXT" means, i am sorry i a am french and don't know all thesubtlety of English language.regards.
It's ok, use it.
Get to the Ulster Grand Prix
Dundrod Co. Antrim
Every August
Learn what fast Really is!
NOT for the faint hearted
or watch it on BBC NI HD the following week
(What is football all about?)
thank you for your post.
I have the same question about the TNTsat, I have a TM6900 super combo, 100cm motorised dish.
the same phantom 752 and the last "SoftcamMotor.zip". by the way why did the name change, from softcam?
did I miss something?
No, this softcam just contains more satellite positions for a motorised system, rathe than just a couple of sats.
Dundrod Co. Antrim
Every August
thank you, if I understand well, it gives new positions for satellits and has no softcamcodes in it? I had the impression it help to decode some staff.
It is a softcam and when loaded in the appropriate receiver will unlock various channels, the softcam file works on satellites form 45? east to 45? west, It will not open everythinh on every satellite the range i gave you is just that a range to & from that the file covers. If you want to see what opens then have a look at this post here: http://www.digital-kaos.co.uk/forums...lators-332141/
phillj (25th June, 2013)
2-6-2013
B***** NOW AND NEXT
regards mdt
badboy1965 (2nd June, 2013), Carew6 (2nd June, 2013), excollier (3rd June, 2013), phillj (25th June, 2013)
Hi guys, I've just purchased a 5402 super + and need to know how to put the softcams on it. Do I need to load Phantom Patch first or is there a newer patch available?
Have a look here at the guide : http://www.digital-kaos.co.uk/forums...chnomate-7310/ for the 5402 it will more than likely be an M2 version if the box is brand new Patch is here: Download center
IPA (3rd June, 2013)
12-06-2013
Thanks to technomaker.
SoftcamAll-12-06-2013.zip
..just click on this Zip file and it should download, then Unzip it and you should have a .key file to load to usb stick and then to receiver.
galinic2 (17th June, 2013)
