Nobody has seen this primate HA HA
Hi, I have a problem with Suzuki Alto 1998 1.0 petrol with Mitsubishi ECU 33920-70f70 check engine flashes constantly and there is an error in a ecu from a "no communication with Immo" . All power supplies are tested for Immo and ecu, I think there is a lack of synchronization Immo - ecu. Attach the dump from the ECU and Immo x24c01 and also the code of the key tiris 4c. If anyone has any ideas please help. Cheers to all. Plamen.
This is a Mitsubishi system.
From what I see... the immo is locked
"If the system is locked the engine warning lamp should flash an error code of 54. If this happens follow the following procedure:
1. Perform a battery reset operation, procedure on the next page.
2. Leave ignition on for 35 minutes.
3. Without turning the key off, connect the tester.
4. Check for fault codes and clear if any are found.
5. Program key, at this stage ignore any error message if displayed.
6. Check for fault codes and clear.
7. Check key for operation.
BATTERY RESET PROCEDURE
Under certain circumstances it is possible for the immobilizer and engine control unit to become locked. This may present
itself in a number of different ways. It can cause :-
- Communication with the programmer to cease.
- The vehicle may crank but not start.
- The immobilizer warning light may be off or on all the time.
- It may not be possible to program transponders/remotes.
To overcome this follow the following procedure :-
- Remove all battery chargers and jump packs.
- Disconnect battery positive lead and negative lead.
- Touch the positive and negative cables together for 10 seconds.
- Reconnect the positive battery cable.
- Reconnect the negative battery cable. "
[QUOTE=plamen 63;1669368]Hi, I have a problem with Suzuki Alto 1998 1.0 petrol with Mitsubishi ECU 33920-70f70 check engine flashes constantly and there is an error in a ecu from a "no communication with Immo" . All power supplies are tested for Immo and ecu, I think there is a lack of synchronization Immo - ecu. Attach the dump from the ECU and Immo x24c01 and also the code of the key tiris 4c. If anyone has any ideas please help. Cheers to all. Plamen.[/QUO
try with new dump
JAVBETT (27th August, 2022)
Thanks for having responded. The first procedure has been tried but there is no success, and I'll try to dump tomorrow. And as you say, let us do good is yeast easier. be healthy
bearheroes (7th September, 2019), JAVBETT (27th August, 2022), johnie-9 (27th April, 2013), mr unlocker (27th September, 2023)
speedservice (17th February, 2020)
Unfortunately the problem is not solved, but I delayed answer because I have a problem with my health. Alto it was very hard sbb t300 original and does not help you may need to look for the option Immo off or emulator. Once again I apologize for the delay but I had problems. Greetings. Plamen
Hello Lattino saga is over and it passed in favor of your old car and prolong life anyway went for scrap. With your dump and started writing new sbb key with work. Thanks and thanks again. Be alive and well and helping people. Plamen
please help synchronization ecu+immo suzuki alto
THX
hi
have similar problem , suzuki alto 1996
key lost
read 24c01 to immobox but no data in dump !?
need pair dump
or other solution
